Reedy Race Of Champions
#137
Originally posted by contact
the evo III has lovely alloy spacers, maybe they are the go?
I have some plastic hex type spacers. i think they are 1.5mm, i wish they were a bit thinner though.
#138
You guys really should just consider cutting the fronts down to 24mm. If you space the wheels out too much you might find that the hex could spin in the 0 offset wheel, rendering the wheel useless.
#139
Wouldn't you have to be extremely accurate? even if u cut it at 1 deg of by the end you might have a wheel which is larger at one end then the other.?...
The thing is to get the right width without stripping the hex in the wheel.
#140
Originally posted by 414m2
True true, but where am i gonna get a lathe and a knife from?
See Coxy & Bradds group at Eastern Creek next time you race there, there is always a tyre lathe there. A knife? Bunnings, Hardware house, Mitre 10, or if you are rich, your LHS.
#141
Nick j just wrapped some deans solder aroound his glow plug and it was the perfect diametre
