D8 Buggy in Aus
#16
yep the kits landed today they are all packed ready to go to the hobby shops today.
your local store should have them next week.
the boxes look good all in kit form.
#19
hara wins!!
#20
yep hara wins, Team HB world champions in 1/8th scale
and 4 in the final
a good effort
and 4 in the final
a good effort
#22
just wanted to know how people are going with there cars.
see how everybody is going.
#23
I love it!
Just one question tho Craig - RE the throttle / brake servo.
I am getting the problem where the servo wires on my Futaba S9351 throttle servo are being pinched / flattened, as the bottom of the servo casing is nearly hitting the chassis.
The rubber plug that exits the servo case is also being deformed, as it hits the section of the radio tray that houses the battery.
Any ideas?
M.
Any ideas?
M.
#25
Mine was the same with Sanwa servos, i ran my wires around the servo instead of under.
The kit went together really well, and I'm looking forward to trying at the track (if it doesn't rain this weekend). I have run it at the park for half a tank to test it out and it felt real good.
#26
when i first done mine i had no instructions i put the reciever up the front and the battery pack in the rear this way i had no probs with running wires , i have corrected it now and i just run the steering servo wire flat under the throttle servo with some fibre tape over it, i try it this weekend should be ok i think. i also made a little hole in the reciever pack lid to run the lead for the battery on the out side behind the transponder this should be ok, probably will have to change it for the wet weather though.
#27
Well started my brushless conversion of the D8 today , you can see the build thread here but need to join to see pics
http://rcmadhouse.com/MadForum/viewt...?p=25016#25016
#29
There are new shafts coming out in the next few weeks from what i understand.
The new one should be fully heat treated.
