Cooling Fans under batteries
Location: If Nissan Motorsport is Nismo, Then Honda Motorsport must be Homo
Hy Guys,
I have heard alot of conflicting info on whether they should be used or not? Some say yes for oboius reasons as the cooler the battery the better but some say this damages the cells as the outisde temp of the batteries is considreably cooler than actual battery temp and destroys or gives false peaks etc etc. Should they be used and if so on NiCads and NiMH's? Should they be used on Charge/Discharge or both? Any help would be great or past good or bad experiences.........
Re: Cooling Fans under batteries
Originally posted by TF3 2SXY
Hy Guys,
Hy Guys,
http://www.rctech.net/forum/showthre...ht=cooling+fan
dont do it heat is better than the cold
just make dammage worse when cool
just allow the air to flow arround them
