-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Help needed re: MARS R (https://www.rctech.net/forum/australian-racing/22590-help-needed-re-mars-r.html)
adz 08-09-2003 06:47 AM
Need advise re: Mars R
Would like to know if the AT:START (auto start) can be activated
by using either BT1 (buton 1) or BT2 (button 2)???????????????
PLEEESE HELP!
Regards.
fastolfart 08-10-2003 03:09 PM
Sorry I can't help you till I read my manual :(
Hmmm, maybe you should read it for me :D
Franky 08-10-2003 03:16 PM
AUTO START? FOR LAP TIMER? USE THROTTLE TO START
adz 08-10-2003 06:36 PM
no i mean the full throtle auto start that can be activated
by pulling the trigger to full and then just backing off a bit
to get full power at the start of the race.
Dragonfire 08-13-2003 07:45 AM
no.
the btn's can only be set to a few simple functions.
the better way to use the auto start is to pull the throttle slightly and hold untill you want to change the throttle.
are you using auto start for stock?
adz 08-14-2003 02:55 AM
Originally posted by Dragonfire
no.
No... just F#?king around.
NR 08-16-2003 04:22 AM
You need a degree in science to be able to use this Radio
Dragonfire 08-17-2003 10:44 PM
how do you figure that? its pretty simple and if you get lost the manual has lots of pretty pictures
fastolfart 08-17-2003 11:02 PM
1st thing, get rid of the ugly standard steering wheel and put on a cool looking custom wheel
(the radio will then obey your ever command and you will go faster) :D
Dragonfire 08-17-2003 11:20 PM
Re: Need advise re: Mars R
i don't know about that, it had the opposite affect on my brothers mars r. anyway why would you change from the standard (foam) wheel to the after market wheel (rubber). in nsw ppl go faster with foam.
(can't wait to see how you bite fof!)
Besercoe 08-17-2003 11:26 PM
Dragonfart, no wonder you are always banging into people at the hill everyone knows you dont have any traction at the hill on foams. maybe the rest of us should chip in and buy you a rubber wheel, it would save us all in frustration and parts:lol: :lol: :lol:
Dragonfire 08-18-2003 10:49 PM
damn i knew there was sumfin wrong with my setup! so where do i get good rubber wheels from? (you know the best places to get rubber i here)
fastolfart 08-18-2003 11:22 PM
Mars R wheel Stinks
When i received my Mars R, I looked at it once and hid in the box till I got a good looking wheel, and I like the smalled diameter with the lower profile tyre as well, just can't get the "DOOF DOOF" thing happening with it though :p :D
contact 08-18-2003 11:47 PM
i put a 20" wheel on the "R" but realised i could no longer see the blue LED and that would just not do!:lol:
Dragonfire 08-19-2003 10:32 PM
Not seeing the blue led is no dramma... install a RGB led.
Jaycar sells an RGB led that cycles through 7 colors. looks cool and makes your radio a one of a kind (take not that it takes hours to get a mars apart!). Unfortanatly it doesn't seem to put other drivers off on the stand. I think i need to make it brighter!
