What does it mean , TWEAK ?
Can anybody give me the rundown on what this means, exactly.
I know it is about suspension tuning and setup but that's it. How important is it and is it able to be sorted out without buying expensive Hudy setup gear? Thanks |
Re: What does it mean , TWEAK ?
Originally posted by Fusion Can anybody give me the rundown on what this means, exactly. I know it is about suspension tuning and setup but that's it. How important is it and is it able to be sorted out without buying expensive Hudy setup gear? Thanks easy way to fix it without buying expensive gear. Get a level table of setup board. draw a centre line and nail some nailed into it so you can place your car on it without the wheels touching. draw a center line on the chassis. then sit the car on it race ready without body. the car should not fall from one side or the other, if it does add weight to the oppisite side. then take off all you shock and check the lenght and spings and fix. check you droop setting if you have them muct be equal. then put them back on. Take the mails out and place the car lined up with center line of the chassis and the setup board. Set your right height and make sure your peload collars are even from sie to side. The car should be right but do this next. with the car in the center lift the car up with a knife via the center of the rear or front and see if both wheels come off the board at the same time. If not then if your doing the rear the the left side comes up first adjust the RIGHT FRONT of the car with more preload or the left front with less preload. this should balance it out. the do the front and adjust it on the rear. Should be a lot better to drive after all that. If you have heaps of difference in the shock preloads then I bet ya your chassis is out of square or tweaked. If you have a problem understanding this just reply again. Coxy. |
thats pretty much well sums it up!!!
the telltale sign your car is tweaked is that it turns (or behaves) diferently turning one way vs the other or on/off power (assuming you have your cambers/toe equal). there are a few ppl with the laser tweak gauges around. c if you can use one if you belive it is tweaked or just follow coxy's instructions to correct anyway. |
TWEEK
Is the sound that my makes when going through corners :ha: :ha:
Re: TWEEK
Originally posted by fastolfart Is the sound that my makes when going through corners :ha: :ha: |
| All times are GMT -7. It is currently 06:44 AM. |
