power supply
Old 08-04-2003, 09:32 PM
Franky's Avatar
Default power supply
Can i use the power supply for PC for the charger input?
there are 12V 8A, 3A, which is better?
another thing is KO Propo pocket booster adaptor,
my charger is 4-7 cells, can it charger the pocket booster,
my charger has auto cut off fet.
Franky is offline
Old 08-04-2003, 10:03 PM
the pc power supply should be ok. just make sure that you don't exceed the max amp of the output (8 or 3 amps as you said above). Just use the 8 amp output and don't charge above that (you should never charge at 8 amps anyway) and you will be fine.
Dragonfire is offline
Old 08-04-2003, 10:08 PM
Trader Rating: 15 (100%+)
with the glow starter adapter, it should only be used on a charger that supports 1 cell charging.
nitro dave is offline
Old 08-05-2003, 12:56 AM
sausage_link's Avatar
u could solder some resistors across the 5v rail to up the voltage. I can get my PSU to put out 15 - 16 volts with the right resistors but they start to smoke
sausage_link is offline
Old 08-05-2003, 02:16 PM
2-Bad's Avatar
Trader Rating: 24 (100%+)
I wouldn't recommend doing this. If it's smoking, then it's overloaded, and from what I understand, you’re taking the computer power supply outside its original design limits. Electricity has a nasty habit of biting back at you when you disrespect it.
2-Bad is offline
Old 08-09-2003, 09:50 AM
OZracer's Avatar
I hope you have a good life insurance policy if you intend using that sort of power supply! I hope the club you are running at has a good insurance policy running as if anything goes wrong with that type of supply and someone gets hurt or whatever they will have to explain how the club let illegal types of power supplies be used. I know that you aren't allowed to use that type of power supply at any of the clubs in Victoria.
OZracer is offline
Old 08-09-2003, 08:55 PM
the resistors smoke because they are only 7 watts and are overloaded... the psu can handle heaps... ive had 2 batt chargers and a car amp connected up to it at once with no drama's
