MTX4R!
Old 10-02-2007, 02:34 AM
Default MTX4R!
hey
im building a mugen MTX4R, and having a problem with the back diff, it has a slow leak of diff oil, i tried putting some gasket goo on the gasket, still no good
anyone else have this problem, or know of a solution??
cheers
DenDen is offline
Old 10-02-2007, 03:02 AM
Originally Posted by DenDen View Post
hey
cheers
95% sure you built it wrong, or a 5% chance you have a defective diff... but i've never seen a defect to be honest.
you probably need to re build it, clean it all up, and re do it dude, diffs don't leak normally unless you overfilled it.
make sure you onyl fill up to where the two cross members of the gears intersect.
TomB is offline
Old 10-02-2007, 03:22 AM
I guess one of the pins arn't properly seated correctly.
rchopeless is offline
Old 10-02-2007, 06:09 PM
thanks guys i rebuilt the diff let it sit over night and it sceems to be fine
DenDen is offline
Old 10-02-2007, 08:22 PM
Slo-MTX4's Avatar
Could also be one of the o'rings around the out drives. If they go hard they can also leak.
Slo-MTX4 is offline
Old 10-02-2007, 09:58 PM
most likely you filled it with too much oil!
twoo is offline
Old 10-03-2007, 09:22 PM
cheers guy, i do find it odd that the MTX4R doesnt come with a front diff ?!
DenDen is offline
Old 10-03-2007, 10:50 PM
occ
Trader Rating: 16 (100%+)
Dude (as TomB says), you dont need a front diff. Just a oneway or a locker is all you need. The RRR doesnt come with a front diff either.
occ is offline
