3PK info
3PK info
Can anyone tell me if i can use standard futaba 40meg crystals with the 3pk or do they use special dedicated crystals?
When changing frequences do i need to change the module or can i just change crystals?
I only need to change modules when changing bands..eg40 meg to 29 meg?
Thanks in advance
Terry
Thanks in advance
Terry
If you have a 40 Mhz Module, then you can use any Futaba 40mhz Crystals... the 3PK doesn't require special crystals to my knowledge... as long as you have the correct band module for it, then you are set...
A BIG THANKYOU....
any idea where is a good plc to get the 3PK in sydney? thanks ..
Coxy.
Originally posted by Besercoe
Dont bother you will pay at least double. I support local shops if they support us, outright profiteering does not sit well with me.
Originally posted by SHARP
Which online shop is good to buy radios from?
http://www.hobbymania.com.hk/
Originally posted by sparksy
Yep... Terry... let me know when you order some more crystals... I need some 40's
Also... the old module from the PJ works a treat with the PK... no HRS but can get you out of trouble when things go bad.
Jeff
