-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   Does anyone have a ? (https://www.rctech.net/forum/australian-racing/171348-does-anyone-have.html)
FLATCHAT 07-06-2007 11:48 PM
does anyone have a bergonzoni 1/5th beetle?
well i do. and i was wondering if anyone has encounter the problem with the alloy wheel hex which is grub screwed to the drive shaft coming through the rear wheel hub carrier.?
it seems very under designed to transmit all that power through to the wheels with a single 3 mm grub screw and a flat on the shaft..
so if anyway knows of a fix for this problem can you please let me know cheers.
NOFX 07-06-2007 11:58 PM
does anyone give a ? :lol:
FLATCHAT 07-07-2007 12:13 AM
you do cause you replied thanks :)
xraymad 07-07-2007 12:39 AM
1/5th problems
Hi Matey,
I have not had this problems.
Try www.rcgroups.com large scale section. Someone in there may have come across the same problem.
FLATCHAT 07-07-2007 01:36 AM
I THINK IT IS HIGHLY UNDER ENGINERED with only one grub screw to transmit all the force to them wheels.
in the book there is suppose to be 2 grub screws but on my beetle there only one on each wheel hex..
it actually lost drive. it spun and melted the wheel hex in the wheel..
FLATCHAT 07-09-2007 05:26 PM
TURNS OUT THERE IS ACTUALLY A UPGRADE OPTION FOR THAT PART..
THANKS FOR THOOSE THAT HELPED
