Go Back  R/C Tech Forums > International Forums > Australian Racing
Chargers RC - Yeronga Onroad >
Old 10-04-2003, 02:47 AM
  #631
TA03F Ecstasy's Avatar
Sam,
What does it say on the back of your instruction manual of the tamiya book?
TA03F Ecstasy is offline
Old 10-04-2003, 02:49 AM
  #632
5am
5am's Avatar
Default ??
I can't remember, do u just want to tell me? Please
5am is offline
Old 10-04-2003, 02:50 AM
  #633
hawker's Avatar
what pitch are you running?
hawker is offline
  #634
5am
5am's Avatar
48 pitch
5am is offline
Old 10-04-2003, 02:52 AM
  #635
hawker's Avatar
why not run the Tamiya .04 module? I've been running it forever, never had a problem at yeronga
hawker is offline
Old 10-04-2003, 02:53 AM
  #636
5am
5am's Avatar
i've found them to be even worse because they're smaller teeth, and i can't reach higher rollouts with the 0.4's which you need if u race at logan
5am is offline
Old 10-04-2003, 02:59 AM
  #637
hawker's Avatar
Out of curiosity, what gearing are you running at meakin, and what target roll out?
ahh! you fell into the same trap I did., i've been doing some working out, and i think that the gearing .04 is possible, it doesn't look right, ie rollout of like 39, but it seems to work well in my testing so far, however, havn't tried it on the track yet.
But i'll be interested to here what your gearing is
hawker is offline
Old 10-04-2003, 03:03 AM
  #638
5am
5am's Avatar
i've only raced at logan once, but will soon be a going regularly, and i will be looking for about 44mm, which seems to be a good choose due to all the info i've got from other people. also, running .04 at logan could be dangerous because small rocks are common at logan, and could easily wrech .04 gears
5am is offline
Old 10-04-2003, 03:05 AM
  #639
hawker's Avatar
yeah, thats fair enough. I've been trying to get out to meakin for practice to sort out gear ratios, but I needed someone to compare speed with, u interested in going out for practice?
hawker is offline
Old 10-04-2003, 03:08 AM
  #640
5am
5am's Avatar
sorry, unfortunately not.
i've been battling a foam tyre problem(i haven't got any), which brad palmer will be very familiar with.
i will be there on saturday, but probably not racing
5am is offline
Old 10-04-2003, 03:11 AM
  #641
hawker's Avatar
no probs
hawker is offline
Old 10-04-2003, 03:17 AM
  #642
I hopefully will be there..just wondering on the time. I recall adam saying that it will be in the day rather than night? So if that is so ...what time till when to when.. and if there is any other information please tell me thanks
Old 10-04-2003, 03:22 AM
  #643
5am
5am's Avatar
if u plan on racing u require foam tyres, otherwise i don't think u'll make it around the first corner without slipping off the track! i go with nathan graham and we usually get there after 4:00pm, and racing usually starts after dusk. wether that is being changed i don't know.
if heavy is there i will be able to buy foams on the night and race. otherwise i will be spectating.
and back to my original question, if anyone has some advice with the spur gears.
5am is offline
Old 10-04-2003, 03:28 AM
  #644
Thanks sam for the info. Well i have used rubbers at meakin...its fun...
handled good..and Adam is to thank for that.
Your question...and i hope this helps sam. Can you get andonized aluminum spur ?
is that possible.. although it would be expensive it would sure last longer if you treat it right.
Old 10-04-2003, 03:31 AM
  #645
5am
5am's Avatar
it sure would last. though i've had this discussion with other people b4, and we concluded that they don't make them because metal on metal would create a hell of a lot of friction, making it much slower. and the sound . i've seen kevlar gears advertised on some american site once, but i can't remember the site and i don't want to pay $20 shipping for something that cost $20
5am is offline
