Go Back  R/C Tech Forums > International Forums > Australian Racing
Chargers RC - Yeronga Onroad >
Old 07-23-2003, 03:19 AM
  #151
hawker's Avatar
shotky diode is for:
when power is applied to the motor, it spins, however, when you slam on the brakes, the motor does not stop straight away, it needs to slow down, so when power stops being applied, the motor is still spinning. As a result, the motor becomes a generator and can feed power back into the ESC which can be very bad. The diode is like a one way valve, it lets electricity pass through one way but not the other. The diode stops power feed back into the ESC
hope that made sense :P
matt
hawker is offline
Old 07-23-2003, 12:25 PM
  #152
R/C Tech Elite Member
heavy's Avatar
Trader Rating: 23 (100%+)
I'll be running a SPort Tuned in Masters on Friday night - does anyone want to do the right thing and help me out with a rollout figure.
heavy is offline
Old 07-23-2003, 01:01 PM
  #153
RoadRunner's Avatar
Default sport tuned
31 to 35 mm seems to be the choices around
RoadRunner is offline
Old 07-23-2003, 11:57 PM
  #154
Default yo
Gdae
Borris is offline
Old 07-24-2003, 03:08 AM
  #155
TA03F Ecstasy's Avatar
Default Wires to use
I'm just wondering what type of wire to use of doing it with the new motor. Any special wire that makes all power go straight to the motor with sacrificing it through heat. Hope you know what i mean
TA03F Ecstasy is offline
Old 07-24-2003, 03:15 AM
  #156
TC321go's Avatar
Default Wires
Hi Jason,
With wires, you generally aim for the lowest guage when you have an option.
ie. mostly 12,13 or 14 guage is the way to go - anything higher is less efficent.
hope this helps
TC321go is offline
Old 07-24-2003, 03:23 AM
  #157
TC321go's Avatar
Default Rollout
Heavy, I'm running a 33.5 rollout in the TC3, good to see you coming to play in masters.
TC321go is offline
  #158
Default Thanks
Thanks Adam. Ready for tomorrow?
Old 07-24-2003, 03:28 AM
  #159
TC321go's Avatar
Default Round 5
Yes I'm nearly ready for tomorrow, The TC3 team car should be ready for a run and again there will be plenty of competition, and I'll take some more photos - Hopefully better ones this time.
See you there
TC321go is offline
Old 07-24-2003, 03:30 AM
  #160
where can i get the cheapest tries from the control tire for pro tours.
Speedy Freak is offline
Old 07-24-2003, 03:35 AM
  #161
TC321go's Avatar
Default Control Tyres
Hi Ian, I believe that Hobby One has the tyres in stock $28.99 a pair - or you could look at getting some used ones from someone at the track.
remember that you also need narrow 24mm wheels and narrow inserts
TC321go is offline
Old 07-24-2003, 03:38 AM
  #162
So did i get this correct. That nob is the postitive end?
Old 07-24-2003, 03:45 AM
  #163
Thumbs up
jason get ready to lose boy. my turn to win the championship.
  #164
TC321go's Avatar
Correct, thats the positive end
TC321go is offline
Old 07-24-2003, 03:51 AM
  #165
Default How much?
How much would male bullet plugs cost for the motor adam?
