Help Please!!!
Hi all,
I bought a jrxs and swapped my electronics over from my old tourer and put them in. I had to shorten the wires on the esc so i cut them back and re soldered them. Now when i go to connect my battery up the motor goes flat out without the esc being turned on. I have a GTX speedy. Does anyone know what could be wrong? I changed motors over and it still does it. Any help would be great. Thankyou |
can you post a pic of ur wiring? it wil make it alot easier for us to help you
Are you sure you are using the same receiver/radio. If you change radios you will need to reset your speedie so that it has the correct max throtle max brake and neutral positions stored.
2 Attachment(s)
Yes everything is the same. but what i dont get is how the power gets to the motor without the esc being turned on.
here are some pics. |
here are some pics. You dont appear to have your - motor wire (blue one) connected to your endbell. |
http://graphics.hobbypeople.net/gallery/551720.jpg
Yah by the looks of this piccy, the middle (blue one) should be Negative motor bound POS + is batt and motor and Bat (-) speaks for itself cant see enough of your car to help n e more |
The blue one is the negative battery wire. There is a black one that goes to my motor which is hard to see but its next to the red one for the motor.
IF YOUR WIRING IS CONNECTED PROPERLY AND YOUR MOTOR RUNS WITHOUT THE SPEED CONTROLLER BEING TURNED ON THEN YOU HAVE A PROBLEM WITH THE SPEED CONTROLLERS MOSFET SWITCHING TRANSISTORS BEING SHORTED .DIODES ARE SHORTED WITHIN THE MOSFET TRANSISTORS.
EXCESSIVE HEAT ON THE SOLDERING IRON HELD ON WIRING CAN CAUSE THE ATOMS THEY ARE IN THE WIRING COPPER OR SILVER TO VIBRATE CAUSING A CURRENT FLOW .EXCESSIVE CURRENT CAUSED BY HEAT CAN DAMAGE THE ESC. THATS WHY THEY SAY DONT SOLDER FOR TO LONG ON THE WIRING AND IF YOU CAN USE CLIPS AND NOT SOLDER ,LIKE THEY DO ON COMMERCIAL AIRCRAFT NOTHING IS SOLDERED EVERYTHING IS CRIMPED. JUST A THOUGHT .I HOPE IT ALL WORKS OUT FOR YOU. |
If you haven't changed the wires from factory set up the black is batt and the blue is motor.
Ok i just realised what my problem is. As Syndicate pointed out i have to put the blue one to the motor and the black one to the battery. So i have the negative wires messed up. I will go and resolder it to see if it works.
ohh ohh
What do i win? :) glad to hear, its usually a case of the most simple thing is the solution, u need to thank atomix too, it was his comment that made me investigate -Reedy |
Yes it is all working good now. Thanks for the fast replies. Thanks to syndicate and atomix and everyone else for the help. Now next time i know to double check. :blush:
| All times are GMT -7. It is currently 01:05 AM. |
