CDC V6b Problem
I have an eagle CDC V6b charger that i have had from new for nearly 2 years. In this time it has worked faultlessly and has not been abused.
Today I have gone to use it after a few weeks break and keep getting an error message stating battery voltage to high. This still happens using different packs of varying capacity - 3300's, 3700's and 3800's. I have not changed power source or any other settings on the charger. The batteries have been discharged and equalised. The first figures I can see on the screen before it beeps, errors and disappears are 13.44 volts. It will do this whether i try to charge, boost or partial charge. It is happy to discharge a battery but they are already discharged, so ends after a few seconds. If i put the same batteries on my other CDC charger, no problems, charges nicely with a starting voltage around 7.4 - 8 volts. Has anyone else had this problem or does anyone have a solution and please don't just say to get a different/better charger. I hate to think the charger has had a total spit. Thanks, David |
Problem solved, i found that the blue wire under the heat shrink was not connected. A bit of resoldering and all is okay now. :D
| All times are GMT -7. It is currently 01:11 PM. |
