-   Australian Racing (https://www.rctech.net/forum/australian-racing-29/)
-   -   LRP ESC Automatic- Reverse not working (https://www.rctech.net/forum/australian-racing/103838-lrp-esc-automatic-reverse-not-working.html)
foaley77 02-28-2006 03:36 AM
got my new LRP Automatic Pro Reverse ESC today I have ran 2 batteries on it already on, the second battery it just suddering stop going in reverse :mad: when I do it just does the normal green display and at full power no light in the manual it says if there is no reverse or brake the pinion or gear ratio is to big the esc was a bit hot so im leaving it to cool off I tried it again and it still does not work why is this happening? I have a 13 turn motor and I have tried a stock motor and still not working.
Havago Racing 02-28-2006 04:09 AM
What was the timing set for your 13 turn?
Was it set to zero degrees or was it advanced?
stock motors are 24 degree advanced.
Johnson 540 motors should be OK.
I had heard that motors with advanced timing and esc with reverese don't mix.
if this is correct you may have stuffed it.
I've mostly always used esc with forward and brake only so I'm not sure personally, it's just something someone told me once.
foaley77 02-28-2006 04:13 AM
I did not touch the timing
tony2 02-28-2006 02:49 PM
the timming of the motor shouldnt really have an effect on the speed control. it just means that a motor with the timing advanced, which is nearly all motors, isnt going to be as fast in reverse. reset the speedy and try again
foaley77 02-28-2006 10:13 PM
how do I reset it? there is no buttons
foaley77 03-01-2006 02:47 AM
I'm returning it under warranty.
tony2 03-01-2006 05:54 PM
yeah sorry. i forgot it was an automatic :p yep return it and get it checked out
foaley77 03-02-2006 04:51 PM
Got an email from Frontline Hobbies and they are going to replace it :cool: hope I get it back Monday.
tony2 03-02-2006 05:48 PM
hehe did you get the email last night? whats you name? i think i wrote it :)
foaley77 03-02-2006 11:10 PM
Shannon
foaley77 03-06-2006 11:30 PM
This is crap I got a new one yesterday and today it has stuffed up again :flaming: all I did was I went in reverse against the wall in the shed then the reverse stop working,LRP must be a shit brand or I have very bad luck.
the buggie was running for about 20 seconds.
tony2 03-07-2006 01:36 PM
You dont have a shottky (spelling) Diode on the motor do you, a small black tube with a silver band around it?
foaley77 03-07-2006 09:29 PM
no I dont think
The OX 03-07-2006 09:54 PM
My Quantam Competition is still available.
No reverse, but a shit hot speedy.
$100 shipped to you.
The OX
PM me
