2017 XRS Round 4 Whalan Reserve 7-8th October
Round 4 of the XRAY Race Series will now be held at Whalan, Located in Whalan Reserve off Debrincat Avenue.
The format will be Saturday being a practice day and Sunday all Qualifying and mains will be run:
Saturday Gates open at 9 to start OPEN Practice at 10:00AM, seeing how the day progresses and the speed differences at this track Controlled practice in groups will most likely be put into place when it gets too busy or at 12:30PM, whichever comes first. Practice will be open until 5PM and the Track will be CLOSED.
Sunday Gates will open at 6:30 and Racing will begin at no later than 8AM sharp, if time is available we will try to open the track for 20-30 mins for open practice. 3 qualifiers will be completed to be followed by Triple A-mains and double lower mains, if time is restricted lower mains will be reduced to 1 Final. Due to running 3 demo classes as high interest has been indicated these classes will be reduced to 2 main finals if time does not allow us to run 3 for all the fixed classes.
An entry form is almost ready so that will be up shortly
We are having Practice/Race days every week up until the event for extra practice
CLASSES:
EP Touring Junior
EP Touring 21.5
EP Touring 13.5
EP Touring Modified
Formula 1
EP GT
12th Scale Modified
Entry fees are:
First Class $20
Additional Classes $15
Control Tyres:
Rush 36X pre -glued (4 tyres with wheels and inserts) $40 per set
These will be handed out on Race day
Junior/Novice will be provided a set of used tyres at no charge and must be returned at the end of racing.
Stock Classes (21.5+13.5) are running controlled motors from Hobbywing these can be bought from HEI or hired for the day
Buy $70
Hire $15
F1 Rules as per on RC Formula 1, Rubber tyres only.
GT will be at per normal Touring car for all rules excluding body shells, Control tyres are to be used for racing. A fixed FDR has been applied to keep racing close and competitive this will be a final drive of 3.3.
All TC classes are as per AARCMCC Rules
All other rules can be found at http://www.rctech.net/forum/australi...ries-istc.html
Is it controlled motor for the novice class?
Yes we will be using the full track layout as this is best, other ideas have either broken cars or we lose the technical parts of the track
In F1 I would recommend Shimizu Medium Front and Ride R1/XR rears as a safe option, maybe shimizu soft or medium rears if its cooler weather
Yes juniors are also to use the control motor
Hope this helps cheers
Jeffrey Mackie
Jeffrey Mackie
Entry Form
Hi Guys,
As Jeff has stated already the 3 demo classes will be having 2 finals only if we get all 3 classes running, but if 2 out of the 3 demo classes get numbers then the 2 demo classes will get there 3 finals. We are going to be running very tight on time as we want to be finished by 5pm so we can get all get home at a decent hour on a Sunday afternoon, so this will require a lot of help from you the racer to be ready to go when your heat is up.
As for the numbers of drivers we have cut it off to a maximum of 10 drivers and a minimum of 8, So if your thinking of racing please get your entries in along with payment to confirm your spot, once we have hit the maximum of 10 drivers for the class will we start taking entries as reserves, so if someone pulls out the next in line will get that spot.
On the Friday afternoon before racing ill be going down to prep and spray the track so there will be plenty of grip for what will be an epic weekend of racing.
Ari will be down there with his coffee cart to provide everyone with food and drinks for the weekend so please support him. Once again we appreciate all the support we are getting and looking forward to the weekend of racing.
Any questions you have please don't hesitate to ask one of us, more than happy to help.
Club account Details
Acc Name: Whalan Model Car Club
Acc Number: 010 877 925
BSB Number: 062 339
Heres the entry form below,
http://bit.ly/xrs_whalan
BSB Number: 062 339
Hi All,
Please see the updated entry list as of 15/09/2017 @ 10am. If your name is not on the list and have submitted before this date/time, please let me know or resubmit your entry just to make sure we have not missed you .
Entries are coming in fast, please lock in yours so you don't miss out! This is looking to be a great turn out, so thanks to everyone that has already entered!
EP Touring Junior
1) Aden Young, Transponder: 6141738
2) Ijah Colet, Transponder: 4225883
3) Brandon Alt, Transponder: 3882716
EP Touring 21.5
1) Hayden Smith, Transponder: 5212712
2) Paul Colet, Transponder: 7486852
3) Ray Zarb, Transponder: (TBA - please advise)
4) Calvin Holmes, Transponder: 5249306
5) Chris Milton, Transponder: 3171261
EP Touring 13.5
1) Tony Smith, Transponder: 2944473
EP Touring Modified
1) Jeffrey Mackie, Transponder: 5503969
2) John Puse, Transponder: 8784500
1/10 GT (Capped at 10)
2) Tony Smith, Transponder: 2944473
4)
5)
6)
7)
8)
9)
10)
12th Scale Modified (Capped at 10)
1) Kane Alderton, Transponder: 2210190
2) Paul Hartmann, Transponder: 4567654
3)
4)
5)
6)
7)
8)
9)
10)
Formula 1 (Capped at 10)
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
Kind Regards,
John Puse
EP Touring Junior
EP Touring 21.5
EP Touring 13.5
EP Touring Modified
4)
5)
6)
7)
8)
9)
10)
3)
4)
5)
6)
7)
8)
9)
10)
1)
2)
3)
4)
5)
6)
7)
8)
9)
10)
Kind Regards,
John Puse
Thanks to everyone who came last Sunday. Was a great day out testing and warming up for the xrs series round 4!
21.5 saw a tight race that was dominated by Chris Milton with pressure early on from Graham Alt. The battle however was between Ray Zarb and the Junior Gun Brandon Alt. Nothing but a hair split these 2 all day, Brandon showing skills to say, next year I'm coming for all you guys!
13.5 was great to have a range of cars from awesomatix, Xray and yokomo. With Damien Zarb too consistent, David Tjhen finished the day off with consistency that Dan Garcia himself couldn't match.
No need to go through modified. With Jeff Mackie on track, not many can beat him at whalan....is this enough of a challenge for next warm up meet to the other mod drivers to come along. You are going to need the practice, as the King of whalan patiently awaits your challenge! 😂🙈🤣
This Sunday we will do it again, Jeff and I will be at the QLD state titles but hope you all get some fun racing in while we are gone!
Hi All,
Please see the updated entry list as of 19/09/2017 @ 10am. If your name is not on the list and have submitted before this date/time, please let me know or resubmit your entry just to make sure we have not missed you .
Where are the 13.5 guys? This is the perfect track for 13.5! The 21.5 list seems to be growing larger than expected with an expected full field of Modified.
EP Touring Junior
1 EP Touring Junior Aden Young 6141738
2 EP Touring Junior Ijah Colet 4225883
3 EP Touring Junior Brandon Alt 3882716
EP Touring 21.5
1 EP Touring 21.5 Hayden Smith 5212712
2 EP Touring 21.5 Paul Colet 7486852
3 EP Touring 21.5 Ray Zarb (TBA - please advise)
4 EP Touring 21.5 Calvin Holmes 5249306
5 EP Touring 21.5 Chris Milton 3171261
6 EP Touring 21.5 Andrew Curless 5938273
7 EP Touring 21.5 Brendan George 5029877
8 EP Touring 21.5 Daniel Hamers 1676627
9 EP Touring 21.5 Carlos Quintana (TBA - please advise)
10 EP Touring 21.5 Adam Murray 7595883
11 EP Touring 21.5 Glen Nankervis 3656701
EP Touring 13.5
1 EP Touring 13.5 Tony Smith 2944473
2 EP Touring 13.5 Scotty Elliot 7013118
3 EP Touring 13.5 David Tjhen (TBA - please advise)
EP Touring Modified
1 EP Touring Modified Jeffrey Mackie 5503969
2 EP Touring Modified John Puse 8784500
3 EP Touring Modified Mark Wallin 9762871
4 EP Touring Modified Nathan Reese 5556825
5 EP Touring Modified Ed Clark 7001311
6 EP Touring Modified Ari Bakla (TBA - please advise)
1 1/10 GT (Capped at 10) Hayden Smith 5212712
2 1/10 GT (Capped at 10) Tony Smith 2944473
3 1/10 GT (Capped at 10) Ray Zarb (TBA - please advise)
4 1/10 GT (Capped at 10) Brendan George 6517144
1 12th Scale Modified (Capped at 10) Kane Alderton 2210190
2 12th Scale Modified (Capped at 10) Paul Hartmann 4567654
3 12th Scale Modified (Capped at 10) Mark Wallin 9683091
4 12th Scale Modified (Capped at 10) Glen Farley (TBA - please advise)
5 12th Scale Modified (Capped at 10) Ed Clark (TBA - please advise)
1 Formula 1 (Capped at 10) Andrew Curless 4697623
2 Formula 1 (Capped at 10) Daniel Hamers 9270171
3 Formula 1 (Capped at 10) Scotty Elliot 4558315
4 Formula 1 (Capped at 10) Glen Nankervis 3220371
5 Formula 1 (Capped at 10) Ian Webber 8852497
EP Touring Junior
EP Touring 21.5
EP Touring 13.5
EP Touring Modified
Calling for late entries!
Hi all,
Please get your last minute entries in for XRS Round 4 at WMCC.
We have another warm up meet this Sunday!
In case some of you may not know, Whalan is one of the largest tracks in Sydney and possibly Australia. Get your practice in to find that crucial gearing ratio and setup.
I will be happy to help advise my knowledge of our home track for those that come.
We will also be testing a sugar coat this week. If it is better, we will continue to lay it down for xrs! Thanks to Sugar Daddy
Kind Regards,
John Puse
Kind Regards,
John Puse
