Go Back  R/C Tech Forums > International Forums > Australian Racing > Australian Events
2016 AARCMCC ACT EP ONR State Titles Feb 27 and 28 >
Old 02-01-2016, 12:38 AM
  #31
ta04evah's Avatar
Originally Posted by evochick View Post
That could not be further from the truth. A short stack motor or rpm motor requires a much different gearing to that of a motor that is more torque based.
+1
Another factor to take into consideration is how much timing do you have set on your motor, some motors perform better with a higher timing stetting, and others perform better with a lower timing setting.
In short, without knowing the brand, model, and how much timing is on any given motor, a very rough gearing estimate can only be given here.
To find the "butter zone" takes experimentation, and noting of what settings work best at any given track.
If you list what motors you have, the guys here can help you narrow down a more ideal setting to start with.
Cheers
Rob.
ta04evah is offline
Old 02-01-2016, 03:40 PM
  #32
nerdling's Avatar
Hi Guys,
It's been bought to our attention that there have been some discrepancies in the manufacturing process for a number of motors on the approved lists for the 21.5 and 13.5 classes.
To be legal, a motor must be approved by and appear on the ROAR motor lists AND conform to the physical specifications as described in the AARCMCC rules.
The AARCMCC specifications can be located at section 10, page 40 of the AARCMCC rules, located here.
It is the competitors responsibility to ensure that their motors confirm to the above rules.
To assist competitors we will be checking motors before the ACT Titles to ensure that they confirm to the above rules. I'm working on having the facility available Friday afternoon and Saturday morning.
During the meeting, motors will be spot checked along with the TQ and podium results as they are provisionally confirmed.
If you have any questions please ask.
thanks
Mark
nerdling is offline
Old 02-01-2016, 04:11 PM
  #33
Wazza22's Avatar
Trader Rating: 28 (100%+)
Hi Mark,
You may wish to add that the motors can appear on the BRCA approved list as well, not just ROAR.
Cheers
Wazza22 is offline
Old 02-01-2016, 04:29 PM
  #34
Supa_18's's Avatar
Originally Posted by nerdling View Post
Hi Guys,
thanks
Mark
To save the hassle of getting there and changing motors. Is there any known motors that ARE roar approved that DO NOT meet AARCMCC specs?
Cheers josh
Supa_18's is offline
Old 02-01-2016, 04:37 PM
  #35
Trader Rating: 43 (100%+)
Can anyone recommend any apartment type accomodation in the area? There's likely a few of us coming down so looking for accomodation with more than one room and self contained kitchen etc.
matrix101 is offline
Old 02-01-2016, 04:49 PM
  #36
PDR
PDR's Avatar
Trader Rating: 31 (100%+)
Cheers josh
Short answer - no.
Longer answer - there's a view that manufacturing tolerances or production issues can result in a motor that no longer meets the required specifications. For example, a manufacturer can build a motor, submit it to ROAR for approval and get the green light, but inadvertently, a motor off the production line could be slightly different and fall outside of spec. Here you have two motors, same labels, supposedly the same, but are materially different. In a more sinister scenario, a motor has been modified, in which case a second-hand owner could be unaware of the change.
AARCMCC's view is that it is the responsibility of the driver to do some basic checks to make sure that the motor still meets the regulations. The tools required aren't exotic and should be readily available at a pit table nearby if you don't own them.
It's not a fab situation, but I think it's a reasonable position to take.
Phil.
PDR is offline
Old 02-01-2016, 05:17 PM
  #37
evochick's Avatar
there is a good guide here on how to check your motors
http://www.teamtekin.com/news/tekin-...spect-a-motor/
from what I have heard the issue is more to do with minimum stator length, but all dimensions should be checked.
evochick is offline
Old 02-01-2016, 05:35 PM
  #38
Hugh Jazz's Avatar
There is Apartments in Tuggeranong.
It might be called Abode. I haven't stayed there but friends have.
http://www.abodehotels.com.au
Hugh Jazz is offline
Old 02-01-2016, 06:42 PM
  #39
ACTMCRC.ORG.AU's Avatar
Entries updated!
We're up to 39, hoping for many more, keep them coming.
The club has practice tyres for sale, $30 per set at our club days leading up to the event.
Club race days before the event:
07 Feb 16
21 Feb 16
Also a reminder, to make it as easy as possible for those travelling, the club will be providing Tables, Chairs and Shade Tents for the use of all competitors during the event.
ACTMCRC.ORG.AU is offline
Old 02-01-2016, 08:24 PM
  #40
I maybe out can not see my new motor on list
B.cassidy is offline
Old 02-01-2016, 08:59 PM
  #41
evochick's Avatar
What Motor ??
evochick is offline
Old 02-01-2016, 09:11 PM
  #42
The new fantom FR-1
Old 02-01-2016, 09:28 PM
  #43
evochick's Avatar
The new fantom FR-1
that's been approved so you are fine
http://roarracing.org/4rmb/showthrea...505-01-06-2016
evochick is offline
Old 02-01-2016, 10:11 PM
  #44
Fantom FR-1
Old 02-01-2016, 10:26 PM
  #45
Tazz44's Avatar
Trader Rating: 22 (100%+)
where do you find out what motors are legal?
Tazz44 is offline
