EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc >
Old 04-29-2013, 06:23 AM
Trader Rating: 19 (100%+)
Default EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc
Durango DEX210
Carbon steering plate and steering brace.
Spare shock towers, front and rear arms.
All the bits that came in the box to convert to mid motor, 3/4 gear gear box and tuning bits.
Captured Losi rod ends on rear inner links.
Shortened battery strap to allow ESC to sit in front of the shock tower with shorty lipo.
Pink washers/spacers.
Two way shock pistons (RCShox), were 4 hole, I drilled out to 6 hole (with correct size rebound/compression holes, lil but dodgy (not 100% straight but if they aren't mixed, not an issue).
69t and 87t spur.
7 pairs of tyres, 5 rear, 2 fronts and 2 sets of front rims. All but one set dyed pink (yellow).
2x Proline Hole shots
1x Jconcepts 3D's
1x Losi X3000
1x Losi Bk Bars
1x JConcepts Rounders
1x Losi Ribs (A-7202).
In decent condition over all, diff could do with a rebuild though, bought it about June last year I think, was raced from then till December, once per fortnight.
$160.
Losi XXX CR
Lunsford Turnbuckles.
Kyosho velvet shocks (will come with losi pink rear and kyosho yellow front)
SPARES:
1x Front shock tower.
4x Front Graphite A-Arms
1x Front EA3 A-Arm
1x Front Pivot Block
1x Front Pivot Block Hinge pin pair.
1x Front Hub Hinge pins pair.
1x King pins pair.
2x Left C-Hubs.
1x Right C-Hub.
3x Right Steering blocks.
2x Left Steering blocks.
1x Hex (goes in the steering blocks for the front wheels).
1x Wing stay set.
1x Motor guard.
2x Idler gears
1x uni joint.
1x Steering rack.
1x Steering bell cranks.
8x rod ends.
1x diff washer set.
2x Rear Losi shocks (threaded, complete).
1x Rear Losi shock (unthreaded, complete).
1x rear Losi shock (unthreaded, missing shaft).
Proline ribs
No rear wheels/tyres.
In good condition all over, aside from a broken rear arm, new ones ordered.
$120
Sold.
Sanwa MX3X
With original box and manual.
Good condition.
$110 Sold
Integy setup station.
Missing one M4 nut/hex.
$50
Pending
Revtech/Fantom Apex 17.5, good condition aside from blown sensor board, done one season of racing I'm told, I bought it and the sensor stopped working on the 2nd meet with it.
Well, it seems this motor is working correctly, the issue was the ESC, may keep it as a spare though.
$20. Sold
Tamiya TZ brushed motor and No-Limit ESC
Spare brushes.
$25. Sold
Hitech Aurora 9 with 2x 7ch receivers and lipo.
With original box and manual/sticker sheet.
$350.
Eagle tree V4 150a Logger
With OSD
2x temp probes.
Throttle sensor cable
Deans - 5.5mm, XT60 adaptors.
$100
Sold
Kyosho Velvet shocks
11x pairs of Kyosho springs
12x pairs of Shumacher springs.
Extras:
4x velvet bodies
2x standard bodies
4x preload adjusters w/2x o-rings.
2x threaded caps
2x threaded bottom cartridges.
A whole bunch of pistons.
$85 will sell with or after the XXX CR.
Will trade for RB6 or RT5, may consider an RB5 SP2 or RB5 SP2 WC.
May also trade for 2x sensored ESC's and a 10.5t sensored motor.
All + postage.
Attached Thumbnails EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-200740y.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-533630_548215688531383_984309310_n.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_3091res.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6989.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6991.jpg
Shimmy is offline
Old 04-29-2013, 06:27 AM
rest of the pics
Attached Thumbnails EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6992.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6993.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6994.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6997.jpg   EP buggies, radios, Logger, Setup station, Shocks/springs, 17.5, brushed motor/esc-dsc_6998.jpg
Shimmy is offline
Old 04-29-2013, 08:04 AM
How much for the xxxcr
greek god is offline
Old 04-29-2013, 09:12 AM
I have $150 on it, probably asking a bit much, make an offer.
Shimmy is offline
Old 04-30-2013, 07:43 AM
price drop.
Shimmy is offline
Old 04-30-2013, 03:13 PM
2158peterg's Avatar
How much for the brushed esc & motor?
2158peterg is offline
Old 04-30-2013, 07:07 PM
Sold sorry.
Shimmy is offline
Old 05-01-2013, 04:26 AM
bump and price drop.
Shimmy is offline
Old 05-01-2013, 06:59 AM
Might be keeping the revtech as a spare as it seems there isn't anything wrong with it after all.
Shimmy is offline
Old 05-02-2013, 08:19 PM
price drop.
Shimmy is offline
Old 05-03-2013, 08:20 PM
final price drop.
Shimmy is offline
Old 05-05-2013, 04:10 AM
bump
Shimmy is offline
Old 05-06-2013, 03:57 AM
Hey mate... I'm keen on the xxx cr if its still available...
Can't pm you for some reason???
Where are you located..?
Thanks...Luke...
Lukey B is offline
Old 05-06-2013, 04:22 AM
Thanks...Luke...
Yup, still available.
I'm in Hobart, Tas.
I'll see if I can send you a PM.
Shimmy is offline
Old 05-07-2013, 06:32 PM
bump
Shimmy is offline
