-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Servo stall prevention (https://www.rctech.net/forum/ask-hitec/947968-servo-stall-prevention.html)
Westline 06-14-2016 12:04 PM
This is a bit off the RC topic but I'm busy with a mechanical clamp that needs to be actuated by a Servo.
The HS 5070 servo will work perfectly for this job.
My problem is opening and closing the clamp with the servo I need to drive the servo into stall to have continous gripping force on the clamp.
I sadly have no space for a spring to hold the force.
Ok my question is can Hitec servos survive continuous stall conditions or can I setup a low resistance high wattage resistor in series with the power to prevent full stall current is drawn.
I have tried a few other suppliers KDS servo died after about 5mins and a Savox I had died with in a minute,
Strangely I have a dirt cheap hextronics servo that was in stall for about 2 hours and works fine.
Hope you can assist me with this.
My product is intended for market later this year and I really would like to avoid early failures in the field.
