-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   hitec IPD receiver (https://www.rctech.net/forum/ask-hitec/84263-hitec-ipd-receiver.html)
ongbenghui 09-16-2005 05:54 PM
hitec IPD receiver
Hi,
I are corrently using 2 hitec receivers, an older HFS-03MM and
the newer HIS-03MK (IPD). I am usering Sanwa/Airtronics Super
Exzes TX. The HFS-03MM works fine without problem with
Sanwa/Airtronics crystal on both TX & RX. I done the same for
HIS-03MK (IPD), however, it seems to glich more on HIS-03MK,
which I thought it should be lesser, or none. I also tried to program
the failsafe. When I test it, with TX suddenly switch off, the throttle
behave as expected (back to neutral), but, the steering servo move
to a full left. Is that normal ?
Thanks.
