-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Hitec Flash 5x V-tail Problem (https://www.rctech.net/forum/ask-hitec/7552-hitec-flash-5x-v-tail-problem.html)
juantrinidad 08-25-2002 06:51 PM
I have a Flash 5X tx and 555 rx radio system. I use it on my Pico Jet flying wing. It works fine on elevon mode but I wanted the use of the flap/spoileron switches as launch and full throttle trim adjustments (flaps as down trim when on full throttle & spoilerons for up trim on launch). This switch only works in V-tail mode.
My problem is when I switch the tx to V-tail mode with servos on channel 1&2 and aileron rudder mix on, I get aileron control on channel 1 but no elevator control on channel 2. Rudder moves the left control surface only.
With the same set up and servos on channel 1&5, I get elevator control on channel 1 (wrong, should be on channel 2) but no aileron control anywhere?
Can I actually do what I want to do on this radio. What is the difference of V-tail and elevon mode? Your help requested.
Best regards,
JT
Tres 08-26-2002 06:34 AM
Drop an email to: [email protected]
He is on this forum a lot, but this may help...
