-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   servo spec..again.. (https://www.rctech.net/forum/ask-hitec/6126-servo-spec-again.html)
sprintr 06-29-2002 06:01 AM
servo spec..again..
Hi
I need the specs for a HS-80 and a HS-225MG,I was wondering if the would work in a micro rs4?
Mike
Tres 06-29-2002 06:13 AM
HS-225BB:
Torque 4.8/6.0v : 54 / 67 oz.
Speed 4.8/6.0v : 0.14 / 0.11 second
Size : 1.3 x 0.7 x 1.3" 33 x 18 x 33 mm
Weight - Nylon 0.95 oz. 27 g.
Metal 1.1 oz.
HS-80:
Torque:36.4 oz/in @ 6.0v
Speed:0.12seconds/ 60deg @ 6.0v
Weight:0.62 oz (Resin Gear) 0.76 oz (Metal Gear)
Size:1.1 x 0.5 x 1.1"
I have seen a lot of the HS-80/HS-81 in micros....
Another new one to consider is the HS-5245 digital Mini servo..
HS-5245
Torque 4.8/6.0v : 61 / 76 oz.
Speed 4.8/6.0v : 0.15 / 0.12 second
Size : 1.3"x 0.7"x 1.2" 32 x 17 x 31
Weight : 1.12 oz
sprintr 06-29-2002 06:55 AM
Hi Tres
Thanks for the fast reply..they are on the way back to hitec to be repaired..
Mike :lol:
HiepNOtik 07-10-2002 09:58 PM
hi I just got a 625 mg and I wanted to know whats the warrantyon it? in the rc car action mag said it had unbreakable metal gear what if it does break will youguys replace it, and alos when I bought my mugen msx3 it had a hitec servo on it the plastic gears was stripped is thier a place that I can go buy the gears if nt then how do I get them?
sprintr 07-11-2002 03:01 AM
Hi HiepNOtik
Hitec has a great repair service,,every servo I`ve sent back so far,they have repaired at no charge..
Send the one with plastic gears back..they will fix it for you..
I won`t use any other kind of servo
Mike
Tres 07-11-2002 04:29 AM
HiepNOtik: All Hitec RCD products are warranted against defects for a period of two (2) Years.
Your LHS should have or be able to get the gear set for you. If you can post the model number I can tell you which set you need.
HiepNOtik 07-11-2002 10:04 PM
The servo came with my car and I have no single or actual reciept that U bought the servo can I still send it in without the reciept?
Tres 07-12-2002 04:16 AM
contact our service department at: [email protected]
or call (858) 748-6948 to verify.
