-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Ko Propo and Hitec servos (https://www.rctech.net/forum/ask-hitec/40-ko-propo-hitec-servos.html)
Matt 08-20-2001 09:02 AM
Does anyone have an idea why my Hitec HS 5925 servo turns almost all the way in one direction when I hook it up to my Ko Propo EX5 receiver? I have tried every adjustment to no avail. The servo works fine in my Futaba receiver. Also are they going to release a programer for these units?
Gary Fliegel 08-20-2001 02:34 PM
What is happening is that the servo lead needs to be changed so that the polarity of the wiring is correct for your receiver. The reason it works fine in your futaba Rx is that both Hitec and Futaba are wired the same. I am not sure how you would need to wire up your connector for a KO Rx tho, sorry. TTYL
Gary F, Team Hitec.
Matt 08-20-2001 05:36 PM
Servo
I wish that it was that easy. I had switched the wiring before this happened. The servo would still work but there wasn't much travel left in one direction.
Gary Fliegel 08-20-2001 08:15 PM
It could be some setting on your radio. This is a tough one to TS over the net. Can anyone at your LHS take a look at it for you and see how your radio is set up? I'll check back in a bit. TTYL.
