Replacement parts for HS7955TG?
From the website there is no replacement part set for 7955TG.
The middle gears are worn out (pinion and the thin gear attached to it) Is there any way just to replace the two using parts from sets that are available? They kinda similar when i checked their pictures. I hope there is a way. im still not sure how to open the case to replace the pinion gear... hmmm. Any experience on this? tnx! jz hoping for a fix, jz in case there's one. -Mike |
I have the same problem. What did you end up doing?
