Digital Servo Modified Program?
I bought a 5625MG for my TC and on the box it has a small sticker stating modified program. I do not have a pit wizard to check what was done. But, is there a "standard" modified setting that is sent from the factory? I noticed some of them had a date listed under modified as well but not this particular one.
The speed would not be slowed down from the factory would it? Can it be adjusted faster than the .13sec at 6v? LHS doesn't have a clue. Thanks Mike |
The modified program sticker just lets our service guys know what batch the servo came from. The specs are all the same.
Mike. |
Thanks.
What are the bennifits of programming a servo.
Thanks |
Most of the programming feaures of servo programing are the same features High end radios perform....
with the exception of DEAD BAND...... You can: slow the servo down change rotation, (CW or CCW) EPA Dead Band plus a few others.... |
I'd say failsafe is the biggest advantage for a car application. The biggest advantage of the programmer is for the giant scale aircraft pilots who use more than one servo for each control surface. If the servos have slightly different center or end points they will fight each other and burn out. With the programmer they can match them perfectly to elliminate this potential problem.
Mike. |
| All times are GMT -7. It is currently 07:40 PM. |
