HFS-3MM glitching
I bought this reciever in december 2003, and it has been working perfectly untill recently. Whenever i race, the car glitches, but right after the race, everything works fine. Nobody was on my channel, and there was no "noise". When i changed back to the stock reciever, my car worked fine. I would try to resolve the problem, but the only way to do so is to run it in a race, wich will hurt my ranking for my local racing season. Is there something that could be wrong? Before switching out the reciever, i checked the connections and crystals and everything was fine.
Did you also change the X'tal when you went back to your stock Rx?
no, i used the same crystals
It sounds like you getting interference from another driver.
Is there anyone close to your CH.(i.e your on 74, someone else on 75) Did you do the test with the stock Rx, with the same guys on the stand? Sometimes, 2 freq's can be added together to cause noise on another freq... |
i looked at the list of frequencies, and no one was within 5 channels of me. When i changed recievers, they did rearrange the people in the heats.
| All times are GMT -7. It is currently 01:37 PM. |
