-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   hitec synthisized recievers (https://www.rctech.net/forum/ask-hitec/295623-hitec-synthisized-recievers.html)
jewn_beef 05-08-2009 12:34 PM
will the hitec synth. recievers hold up to 1/8th buggy truggy racing without problem heard they have durability issues
BRENDAN LUGO 05-08-2009 03:27 PM
Yes it will. As with any receiver install you need to make sure it has adequate insulation from vibration.
jewn_beef 05-13-2009 10:36 PM
can i show up at hitec and buy one of these recievers or do i haveto order it through a LHS need it this weekend
Billy T. 05-28-2009 09:06 AM
Sorry for the late reply, but we are unable to sell direct to the public. Gotta keep the LHS's alive.:nod:
Zerodefect 08-02-2009 05:55 AM
I'm loving my Synth. Its been in a Rc8, B44, and now in a Xray 809. I wrap it once with the 1/4" Rx foam used in airplanes.
My B44 was the hardest test for this Rx. It was double servo taped to the carbon fibre. Nothing but 2 layers of servo tape between it and getting slammed hard into the ground twice every 28 seconds (1 lap).
After being moved from car to car constantly for about a season, because it was the only reliable RX I had, the first problem was some major glitching because somehow the antennea was pulled off the board. I opened the case and carefully soldered the antenae back onto the board. Works fine to this day.
Is it true this RX can be run with a 2 cell 800mah Lipo without a regulator?
I have 2 7955 servos connected to this Rx and thats a lot of work for my 7amp Novak regulator to keep up with. My 10amp Castle reg set to 7.0 volts kicked the bucket a while ago.
