-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   servo reversing (https://www.rctech.net/forum/ask-hitec/294254-servo-reversing.html)
big deee 05-03-2009 01:11 AM
servo reversing
I'm running two hitec 7955tg servos through a y cable and wanna know how i can reverse one of the servos. Its for a 1/5 scale car where one servo is for throttle/rear brake and the other is for front brake. When i go throttle on the radio the one servo goes in the right direction while the other servo will apply the front brakes. Can you explain if i have to go into the servo which wires i need to swap.
aaron2u 05-03-2009 06:45 AM
Is there any way to change the side of the servo you're using?
Meaning, if you have the horn pulling at 90 degrees, maybe move it to 180 so it pushes instead of pulls?
big deee 05-03-2009 12:26 PM
yup got it good now. It was like 2 in the morning last night and i just couldn't think straight. But ya fliped the horn around bent up some linkage and its a go.
aaron2u 05-03-2009 12:44 PM
cool beans
