hitec hs-65mg micro servo in robotronic scalpel
I would like to use the terrific, hitec hs-65mg in my robitronic scalpel 1/18 pan car, but the servo arms in the scalpel kit do not fit the spline pattern/shaft size of this servo (the Scalpel steering arm are too big - likely designed for futaba or other brands of servos, even though the kit indicates them to be hitec compatible.)
I would like to use the Scalpel/futaba steering arm with this great little servo, rather than modifying a hitec servo arm. So is there a "hitec-futaba" spline adapter that I can buy, that fits the shaft of this great micro servo?
Thanks!
Farzad
Thanks!
Farzad
The 65 uses a different spline than all other Hitec servos except the 56HB and 125MG. Most likely you will need to use the horn that came with the servo to make it work.
Mike.
Mike.
