Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Servos capable of no lipo regulator >
Old 03-02-2009 | 11:49 AM
  #16
MikeMayberry's Avatar
Company Representative
We'll have three Hv servos to start and them perhaps more will follow.
I have run the 5955's on 2S Lipo with no issues but the motor in the 7955 is definately more capable of handling the higher voltage vs. the 5955, so I can't "officially" suggest it.
Mike.
MikeMayberry is offline
Old 03-02-2009 | 01:13 PM
  #17
mechanic77's Avatar
So what are the servo numbers and specs on the HV servos? Also, when are they going to be available?
mechanic77 is offline
Old 03-04-2009 | 01:04 PM
  #18
HS-7954SH (Same as the 7955TG but with Steel Gears) $109.99
HS-7949TH (Titanium Ultra Speed) $149.99
HS-7950TH (Titanuium Ultra Torque) $149.99
Available: June '09
Mike.
Old 03-06-2009 | 09:33 PM
  #19
jldjlaudio's Avatar
I was going to try it on my 5990tg but didn't because i didn't know forsure and I wanted to get this one but now I dont think I'm going to if it can't handle the power http://www.advantagehobby.com/produc...cat=989&page=1
jldjlaudio is offline
Old 03-06-2009 | 09:36 PM
  #20
jldjlaudio's Avatar
If anyone wants to see a list of all their servos and specs and ones that are comming look here... makes finding a servo by torque and speed so much easier. http://servocity.com/html/hitec_servos.html
Old 03-07-2009 | 10:28 AM
  #21
dlovett2361's Avatar
Available: June '09
Mike.
Just in time for the rest of the Texas State Series!
dlovett2361 is offline
Old 03-25-2009 | 08:26 AM
  #22
Just want to throw this out there, the HSR-5980SG (robotic servo) will handle 7.4 unregulated... delivering - 333.29 / 416.61 oz.in (6v/7.4v).
I know some people say you shouldn't run this in a 1/8 scale buggy, but I have been for a while (prior was a rock crawler), and nothing but awesome performance.
Hitec edit: This servo is NOT recommended for R/C applications. Using it with R/C radio systems you would loose most of the resolution in the servo. Use the 7955TG. It will handle the higher voltage, has a titanium gear train and has the heat sink middle case to help dissipate the heat.
JGruber is offline
Old 04-01-2009 | 12:35 AM
  #23
Carbon8ight's Avatar
got it,, use the 7955TG if your unregulated until June,, then the new ones will be available..
seems like the 7955TG is suited for steering?? is there one that is recommend for throttle/brake activity,, possibly with a little less .oz's ??
Carbon8ight is offline
Old 04-01-2009 | 07:05 AM
  #24
BRENDAN LUGO's Avatar
I'd use the 965MG or the digital version 5965MG for the Throttle/brake.
BRENDAN LUGO is offline
Old 04-01-2009 | 07:25 AM
  #25
drperry's Avatar
Until the new Hitec HV servos come out, the only one that can officially handle unregulated LiPo voltage with no ill effects is the 7955TG.
drperry is offline
Old 04-01-2009 | 07:26 AM
  #26
jldjlaudio's Avatar
Yeah and if you run one of those then you CANNOT run straight lipo, you have to use a regulator or your throttle servo will go up in smoke!! Steering will be good but not the throttle! Im going to be running 2 7955tg's..
Old 04-01-2009 | 07:40 AM
  #27
Yeah I know it's not supposed to be used in a RC application, but in Rock Crawling, the resolution doesn't mean anything, it's all torque we look for. And it does work very well in a Crawling application.
I have since moved to the 7955TG in my Losi 8T. It was just an experiment until I got the 7955TG.
JGruber is offline
Old 04-01-2009 | 08:50 AM
  #28
drperry's Avatar
High resolution servos are definitely useful in rock crawling!
How else are you going to catch that 1/32nd of an inch worth of egde?
drperry is offline
