INITIAL KICK on TURN ON
hello
I am controlling a REEDY DS spec Motor made by Team Associated with a Hitec SP 1801 n speed control. When I turn it on at the Speed Control swtich, It gives an initial full rev kick for a tenth of a second or so. Can I stop this as it is damaging my setup. Thanks V |
Is your transmitter already on before you are turning on the speed control?
not using a transmitter or reciever
am using an arduino to controll the controller.. but the arduino IS NOT sending the KICK TURN ON command |
It can be normal for servos to momentairly twitch when power is applied to them in a normal R/C setup. Some receivers are a little bit more prone to it than others but since you are not using a normal setup I cant really say what is causing your issue. It could be the same voltage spike when powering up your controller board that is causing it.
| All times are GMT -7. It is currently 01:02 PM. |
