-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Hitec 645MG issues (https://www.rctech.net/forum/ask-hitec/248599-hitec-645mg-issues.html)
clodsrule 10-20-2008 03:47 AM
Hitec 645MG issues
I have always ran the 645MG in my RC trucks since it came out and have never had an issue. I recently bought 2 more645mg's from my local hobby shop. With in an hour, both servos stripped out on my TXT-1. I was crawling up my sidewalk when they stripped. Is there something different about the 645mg's now? The gear that stripped was the bigger gear inside that is very thin. Both servo's stripped the exact same gear. I just wanted to ask and see if you had any insight on this matter. Thanks in advance.
BRENDAN LUGO 10-20-2008 07:28 AM
Nothing has changed on those servos since their introduction. Which gear stripped? Was it the hybrid "MP" gear which is a nylon spur with a metal pinion gear in the center?
clodsrule 10-20-2008 08:00 AM
yes i believe that is the gear that stripped. without having the servo in front of me i cant be 100% sure. im at work now. It looked like a metal coated nylon gear. I was just dumbfounded that they stripped. I have always and will always run hitec servos. I was just curious if something changed in the production of them. I can let you know this evening what gear it was exactly. Thanks for your quick response.
BRENDAN LUGO 10-20-2008 08:26 AM
Let me know. I'll see if I can get you a replacement gear or a set if need be. :tire:
clodsrule 10-20-2008 10:27 AM
i sent you a pm. i will follow up tonight when i know the exact gear. thanks for your help
clodsrule 10-24-2008 08:13 AM
Here is a pic of the gear that stripped in both my my new 645mg servos. I found this pic for reference on the internet as well. Let me know if you can help me out. Im sorry it took so long to get back to you, but ive been working alot.
http://i113.photobucket.com/albums/n...ec645gear1.jpg
BRENDAN LUGO 10-24-2008 08:32 AM
PM me your shipping info.
clodsrule 10-24-2008 10:06 AM
PM sent and thanks again for your help. I really appreciate it.
bambikilr 12-08-2008 12:34 PM
I personally would recommend an MG servo with at least 200 OZ @ 6.0v
I have never ran a Clod but I know they are big and heavy
I have an AX-10 , and blew out a 645MG.
Then I switched to 985MG. No problems ( about 50 hours on truck with 985MG)
My advice is to stop spending money on mediocre servos and many gear kits.\
Buy A 985MG or 7955TG, or the newest and strongest (most expensive)
7950TG 444OZ @ 6.0v:weird:
