Hitec servos with KO Propo Receiver?
Hi,
Am I able to use the Hitec HS5925MG Servo with a KO Receiver? In other words... are they compatible? Thanks. |
Yes you can. You'll have to check the wiring order of the servo. For a KO the red (positve wire) should be on the outside, the black (ground wire) should be in the middle and the signal wire should be the inside wire.
KO is wired the same as Hitec, Futaba, JR, and Airtronics "Z" connectors so you can just plug and play!
Mike. |
| All times are GMT -7. It is currently 12:33 AM. |
