Go Back  R/C Tech Forums > Company/Manufacturer Forums > Ask Hitec
Has anything changed on the hs-65mg servos? >
Old 02-12-2008, 09:38 AM
Default Has anything changed on the hs-65mg servos?
I have had quiet a bit of bad luck with this model servo recently. It started out with the first one I bought about 4 weeks ago, right out of the box the servo would turn for a few seconds with a glitch, then stop and just hum and get really hot. 2 weekends ago I bought another servo (same model), it actually worked ok at first (I installed it in a rc18t with the 18t hitech servo saver). The following weekend it started acting up, when you would turn the car on, the servo would turn to one side and stay there for about 15 seconds. Eventually you could turn the wheel and it would turn a little and then lock in the full direction you was turning for a second or two. After about 15 more seconds of that, it would just start working fine. I finished that race night with no problems, but this past Saturday the servo died completly. I installed a 4th hitech servo in my car Saturday night and havnt had any problems out of it. I have 2 servos that are packaged up and fixing to go back, I was just wondering if I am having some bad luck or if anyone else has been having problems lately?
arstron is offline
Old 02-13-2008, 08:39 AM
chewiefttc4's Avatar
Trader Rating: 26 (96%+)
what radio are you using..
its a analog servo. you probably have that channel in digital mode. that will mess up a analog servo preety quick.
check it out
chewiefttc4 is offline
Old 02-13-2008, 12:53 PM
I am using the futaba 3pm-2.4 tx/rx but I am running in ppm mode.
arstron is offline
Old 02-13-2008, 08:00 PM
find out if theres a way to adjust what kind of servo you have in what channel..
my buddy has the same issue.. he has to use digital servos.. because he doesnt know how to change it.
