help
i like to noe can i use hitec reciever wif futaba 3pjs, if can wat do i need to get??
thanks |
Which Rx?
If DCX, you need to use Hitec Dual Conversion X'tals. |
i juz wan to noe which rx can be used wif my 3pjs
You can use either a DCX(Dual Conversion) or a HFS-03MM(single conversion). With the DCX you will need specific DCX crystals. The HFS should work with Futaba crystals. If you have no crystals or Rx's yet, I suggest the DCX. Much stronger filtering. TTYL.
Gary |
thanks but wat does single or twin conversion means?? and can i use futaba crystal wif DCX?? coz my local shop doesn't sell hitec 75mhz crystals
No, you unfortunately can't use Futaba crystals with the DCX. The DCX reciever has a dual conversion, filter thingee-magig. It kind of 'reads' or 'filters' the signal from the Tx twice, so that glitching is reduced over a single conversion Rx.
It works well, but if crystals are a big problem, then as Gary said, the HFS-03MM should be what you look for. Personally, just order a bunch of crytals at one time. |
| All times are GMT -7. It is currently 08:31 AM. |
