Problams
Hi i have a hitec servo it can with he T3 and i took it out and put it back in and when i turn the wheels it is hitting the servo???? what should i do. it can turn one way a lot and the other way not as much?? thanks
Sounds like maybe your servo horn is not centered.
Or EPA/dual rate is off. What type of radio do you have? |
Im useing a futaba computerized radio. and i checked it is centered.
what are your L & R epa's set at?
about perfectly straight.
Try setting your end points on the radio.
That may help.???? |
do yuo think it might need longer arms to where it ataches to the servo?
What arm do you have on it now?
The stock on that came with the car.
| All times are GMT -7. It is currently 01:19 PM. |
