Running two HS-5735MG in my 1/5 scale car
Hello, I own an FG Competition Evolution 1/5 scale car and have been running one HiTec 1/4 scale HS-5375MG servo for steering, however I have decided to run two servos. What is the correct way of linking the two HS-5735MG steering servos together? If it helps, i'm running a Futaba 3PK HRS radio.
John
John
You could probably use the mixing and plug one into channel #1 and the other into channel #3. However, you may need to use the mixing for the front brakes to the throttle channel; in that case you would just use a y-harness. It would be best if you could match the servos to each other with the HFP-10 programmer so they have the exact same center and enpoints, that way they don't fight each other.
Mike.
Mike.
