-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   SRX aggressor not working (https://www.rctech.net/forum/ask-hitec/163639-srx-aggressor-not-working.html)
danimal1965 05-16-2007 11:19 PM
Hey I walked away from the rc10GT for the last couple of weeks waiting for a new servo to hopefully fix my glitch. It arrived today, a JR Z590m torgue race servo. All happy i removed the second servo that i'd tried for the throttle.I have also changed the mix for the steering, removing the hitec 645m and trying 2 different AE servos.I added about 5 inch of antenna acouple of weeks ago too then shrinked wrapped it back on itself on the antenna tube.(only b/c the stupid cat chew on the extra wire) Anyway i installed the new JR and left the ae 1903mg on the steering thinking i'd be burning nitro in 10 minutes. Not happening its still glitching. What i hadn't mentioned was both servos were doing it but the steering was about 85%(hardly noticeable) better than the throttle. Now i'm PO and totally confused. I start touching things to see if it gets worse or better , well it gets bad when i touch the brake linkage. Confused again I remove the brake linkage off the servo and brake arm as well as removing the doubled up antenna wire so it hangs loose again. well the glitching stops.I put a piece of shrink wrap on the threads for adjusting the brakes to keep the metal on metal parts apart. I then put the linkage threw the arm for the brake lever and it starts glitching again. I lay the brake linkage on the center of the horn-less new metal servo and as soon as i let go the glitching stops. I grab it and it glitches. I must be the glitch.LOL .I put it all back together again with the linkage hooked back up to the servo and it glitches again when i turn on the powerI've checked everything else(batts,antenna, bare wires etc..)The only thing i haven't done is open the receiver box or re-root all the wiring,I've read that some bec systems will limit the power to the high powered servos and using a" Y" wire connector will by-pass the bec. How ever i don't think that this Hitec SRX has bec. Tonite i gave it one more chance. i re-built the 311 servo and installed it for the throttle. Now when i turn on the radio the steering and throttle servos center but then theres nothing. no functions on the truck work.The green light is on for the reciever . I've checked everything but the transmittor and reciever. Not sure whats wrong now. the last time i used the gt evrything worked but the throttle was very glitchy. Dan.
Tres 05-17-2007 06:46 AM
What Rx are you using?
danimal1965 05-17-2007 09:28 PM
Hey Tres, its the HFS-03MM. Dan
danimal1965 05-24-2007 04:42 AM
Any ideas? thanks.
Tres 05-24-2007 10:20 AM
Have you tried a new X'tal?
danimal1965 05-24-2007 08:42 PM
got a crystal and rx in the mail. Thats the only stuff not checked yet. Hopefully. My gt is getting jealous of the t4.LOL thanks for responding. Dan
danimal1965 06-10-2007 04:36 PM
Hey Tres, my LHS is not having any luck finding crystals for my radio. its been 5 or 6 weeks. I've got 2 recievers. the one thats glitching in the gt and a new one. But no ch70 (75.590) crystals. Can you or anyone get me some. Thanks. Dan.
Tres 06-10-2007 07:53 PM
If you local shop is having issues finding one.
Tower shows 75Mhz x'tals in stock.
danimal1965 06-10-2007 09:52 PM
Hey tres, was hoping for my lhs, the last time i ordered from tower it took 4 weeks. I guess i've been waiting for longer already:lol: Thanks. Dan.
