-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   HS5745MG receiver pack question (https://www.rctech.net/forum/ask-hitec/147418-hs5745mg-receiver-pack-question.html)
tmaxxking 01-31-2007 07:44 PM
a guy at a local hobby shop told me a 5 cell c size 3800 or 4200 pack would kill the servo
he said in the passed month he has seen 2 fry from heat do to too much voltage
for the higher mah packs
the servo is in an fg 5th scale
thanks in advance
Tres 02-01-2007 06:38 AM
The sub C packs allow for higher amp draw than normal Rx packs.
Not voltage.
If something is not setup correctly or if something puts the servo in a bind.
The higher amp draw can cause more issues.
This is true with any servo.
1/5 scale is very brutal on servos.
tmaxxking 02-01-2007 07:17 AM
the whole rig electronics and all have less then 5 tanks on it
he's more of a parking lot cruiser then off road
kind of pointless for a 5th monster truck
he also has the habit of leaving the on/off switch on
what mah would you suggest to run
and i didnt even think about the amp draw
thanks man
T493 02-03-2007 07:36 PM
Well I know on the stock tamiya ESC's they wun the reciver off the battery pack. That is a larger cell and 3800 MAH. That system does not wreck any servo's
Tres 02-03-2007 07:43 PM
We are talking about Rx packs.
On electric cars the the BEC of the esc/RX limit amperage to the servo.
T493 02-04-2007 08:22 AM
I used to run 7.2 volts on the servo with no trouble.
Tres 02-04-2007 08:30 AM
You ran the servo leads straight to the battery and not into the Rx?
