Need Advice...
Hi Hitec Peeps...
I have in my possession a JR R-1 PCM radio, and I require two servos... so im looking into getting Hitec servos... now i dont want to spend too much on the servos either... so I was wandering what would be good for steering and throttle servos? I'm driving an MTX-3 1/10 Scale Nitro... Any suggestions? Not sure about digital servos... does this mean i will need to get a higher mAH receiver battery? and have to keep charging between heats... But anyway, i wasn't quite sure if a 625 or even a 525 will do the job or not, cheers! :cool: |
If you can, digital are the best.
They do use a little more power. The HS-525 would be great for throttle. HS-645 or HS-625 for steering.... |
can i use the 625 for throttle as well? because i think its rated at 0.15 @ 6V, where the 525 does a 0.17 @6V? :confused:
Yes....
thanks...
The 525 is the best throttle servo on the planet! I have never had one fail in 6 years. It is faster than the 625 by a hair but has better resolution due to the 5-pole motor.
Mike. |
oh buggah, now you tell me... :lol:
i went ahead and bought the HS625 for my throttle... and an HS645 for my steering... this should still be okay right? :rolleyes: |
Yes you will be fine. If you find that the 645 is a tad slow for your steering tastes, swap the two around. TTYL.
Gary |
625 @ 6V = 0.17sec
645 @ 6V = 0.20sec is there much of a difference between 0.17 to 0.20 in real time and senses? :confused: |
I can feel the difference. Remember those figures are for 1/2 a rotation of the servo(60 deg) so if you were to go through a chicane it would take the 645 longer to go from lock to lock. Try them out, you may be suprised. TTYL.
Gary |
| All times are GMT -7. It is currently 01:14 PM. |
