-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Glitching#2 (https://www.rctech.net/forum/ask-hitec/1319-glitching-2-a.html)
7even racer 11-06-2001 07:35 PM
Glitching#2
I just got a new hitec servo (HS615MG) i'm using it in a RC Lab and a little before i got it, my car would glitch badly, it only glitches when i steer left to right or right to left then it cuts out for a second then comes back on. i'm not saying its the servo but does anyone have any idea what it is?thanks
7even
Gary Fliegel 11-06-2001 08:23 PM
Was your car glitching prior to using the servo? Also what radio are you using? TTYL.
Gary F.
WailinOnYa 11-06-2001 10:31 PM
7even racer: This may be a long shot, but check the servos plug and see if the pin sleeves themselves are snug in the plug and that none have play in them allowing one or more of them to move around. My nephew has a 605 and his was basically doing the same thing that you described, it would just cut out for no apparent reason. I thought it was a glitch, but after looking it over and testing it I found that one of the inserts was loose in the servos plug allowing it to move around from the motion of the car. It was making contact on and off with the receivers pin, which was making it act like a switch. After fixing it so that it was tight in the plug, he never had a problem again!;)
7even racer 11-09-2001 12:38 PM
yestrday i went to my LHS and i found out my prob, it was my speedo, since i bought it at that shop they gave me a new one for free, so its all good now, thanks
