-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   HS-81MG buzzing (https://www.rctech.net/forum/ask-hitec/110237-hs-81mg-buzzing.html)
Lextek 04-15-2006 04:52 PM
HS-81MG buzzing
I recently installed a HS81-MG in my Vendetta. I use the CF servo holdown. The sero "buzzs" until I move it left or right. What up with this?
Tres 04-15-2006 07:48 PM
Sonuds like the linkage is a little tight...
Lextek 04-15-2006 07:54 PM
I have checked and nothing is binding. I was wondering if the pressure from the top plate could cause the servo to "bind" internally. The Duratrax servo hold uses a CF plate and stand offs to squeeze the servo to the chassis.
BRENDAN LUGO 04-18-2006 02:21 PM
The pressure against the servo case can cause this buzzing. Also if the servo case itself is a little tight it can also cause buzzing. In this case you can loosen the case screws slightly to releave the pressure.
Lextek 04-29-2006 06:19 AM
I backed off on the top plate and the screws in the servo cast just a touch. No more buzzing. Thanks.
