-   Ask Hitec (https://www.rctech.net/forum/ask-hitec-40/)
-   -   Hs 605bb Big Problem! (https://www.rctech.net/forum/ask-hitec/10093-hs-605bb-big-problem.html)
kilokhan 11-27-2002 06:19 PM
I'll ask this question here lso...
Ok that servo i got,.... is acting kinda wierd.
I used 6005BB for my stering and futaba3003 servo for my throtle.
When Ever i moved my stering my throtle move.
some kind of interfierence happen.
It happen worst then my engine are started.
it moves like crazy and uncontrolable BOTH SERVO.
Any idea why ?
Apply greese IN my Hitec servo?
I open the servo and it seems like everything is Metal.
METAL+METAL=INTERFIERANCE rite ?
Reply fast.
Thanks if u people can help
Gary Fliegel 11-27-2002 06:51 PM
You can put a little grease in the servo gears if you like, but it sounds like you have a different problem coming from somewhere in the car. Let me ask a few ??. What kind of car is it? What kind of radio are you using? I'll check back in a bit. TTYL.
Gary
kilokhan 11-27-2002 07:16 PM
1 Attachment(s)
FUtaba am 27
T2PHKA Model
I had change 2 radio kits alredy
RS4 2
Stock engine
I'll enclose my car pic
Gary Fliegel 11-28-2002 04:32 AM
By looking at your pic I can see one problem already. Put another collar on the front side of the brake linkage and use some fuel tubing to hold the brake lever in place. That is steel to steel contact there and it can generate the problem you are talking about. the fuel tubing will hold the linkage and reduce the vibration. It also looks like you fuel filter may be rubbing on something. Try to isolate it from any of the metal parts on your car. Anything that is metal to metal and rubs can give you the problem your talking about. Also check and make sure there are no small nicks in any of the electrical wiring. If there is just throw some shrink on it to fix it. Very nice ride BTW!! Try that and let me know if it fixes anything or if the problem still exists. TTYL.
Gary
kilokhan 11-28-2002 08:52 AM
HHmmm i checked my Hitec servo wire it have some burst part..
in the middle of the wire.
I'll hcnage the whore wiring tomorow with a new 1.
I got a spare wire.
the Linkage/filter u are talking about is made from aloy.
So there's should be anything.
Well the problem keeps on comming...
Once i move my hitec servo everything moves..
kilokhan 11-28-2002 10:32 PM
Hmmm the problem still exist.
I got the servo out and fit it in to the electric car and still have wacko problem.
I guess switching to a FM receiver will help ?
Oasis 12-13-2002 10:04 PM
Get rid of the 605 and get a better servo.Go with a digital
mb racer 12-13-2002 10:50 PM
kilokhon
check out your pic!! re-route your antena ...this should help you glitching problem's.....:sneaky: :sneaky: :sneaky: :nod: :nod:
