New layout at TVR
Old 01-15-2018, 02:14 PM
  #16
Trader Rating: 66 (100%+)
That track is larger so I can see the e-buggy working there. Only two classes? Are the classes split up or all together?
Thunder Trail is offline
Old 01-15-2018, 05:45 PM
  #17
Originally Posted by biggen
The past few years I've been traveling to radioactive raceway in Kentucky to race there track track is a high traction hard packed clay track and the biggest classes of late has been 8scale ebuggy and 4wd 10scale buggy , all short corse classes have died out and has been very few 2wd buggy class
Jimmy do you like that high bite clay? GS Hobby has it and it's wicked fast and easy to take care of.
jdwarne is offline
Old 01-16-2018, 12:23 AM
  #18
biggen's Avatar
Yes the hard pack clay is awesome and actually tire wear isn't that bad if it stays damp and traction is awesome we run usually super soft compound , I usually run ss aka typos and there hooked up
biggen is offline
Old 01-16-2018, 12:27 AM
  #19
biggen's Avatar
The big classes there is ebuggy and 4wd buggy , usually only like 3 or 4 4wd sct trucks show up last weekend there wasn't any and there was 4 of 5 2wd buggy , there track is roughly 100x50 I'm not sure of the size of your track so I'm not sure how ebuggys would do there
biggen is offline
Old 01-16-2018, 06:13 AM
  #20
We wont run any 1/8 scale or 4wd SC. Looks like we will stick with 2wd Buggy, 2wd Short course, 4wd buggy.
jdwarne is offline
Old 01-16-2018, 08:23 AM
  #21
biggen's Avatar
Sounds good
biggen is offline
Old 01-18-2018, 10:04 PM
  #22
That's a good plan. They use that surface at the Warehouse Track and you can run the same slick tires till the foam pops. That's about 2,000 laps on barcodes. May not seem long enough if you do a lot of 400 lap practice sessions every week. Track does crack bad if you let it dry out completely. Some sugar and water or cheap soda pop bring traction to velcro level.
Yes Sir, that GS track is quick. Squirt and turn! It does require fast reflexes. If I blink I overshoot the apex. Not so quick these days.
Old 01-19-2018, 10:07 PM
  #23
rchogfan's Avatar
#ProlinePrimes, it's nice pulling your buggy off and it still being spotless clean. Consistent fast track. If you're available come to Wingo Kentucky for the February fallout race. Should be a lot of fun plus insight on what some Arkansas guys will be running.
rchogfan is offline
Old 01-24-2018, 07:05 PM
  #24
Thanks Calvin for the info on the Wingo race. Ill try to make it over there. What classes are you running?
jdwarne is offline
Old 01-25-2018, 10:03 AM
  #25
rchogfan's Avatar
2wd and 4wd buggy for sure.. maybe a fill in class of something else. My son will probably run 13.5 buggy.
rchogfan is offline
Old 01-25-2018, 10:10 AM
  #26
rchogfan's Avatar
Bring u a couple classes to run so you can race and not be on microphone the whole time.
rchogfan is offline
Old 01-25-2018, 08:36 PM
  #27
Lol
jdwarne is offline
