Like Tree1Likes
FEAR FARM RC RACEWAY
Old 09-11-2011, 02:05 PM
  #3661
aznitronut's Avatar
602-418-3846, Try Kenny Brosh.
aznitronut is offline
Old 09-11-2011, 02:41 PM
  #3662
losi_racer's Avatar
Trader Rating: 25 (100%+)
Originally Posted by rockstarjohn View Post
well my friends and i are down for the drive out there. who do i call to find out for sure
as of right now nothing is official . Joey him self said November but no date is set
losi_racer is offline
Old 09-11-2011, 02:43 PM
  #3663
aznitronut's Avatar
Call kenny
Old 09-11-2011, 02:49 PM
  #3664
Jaz240's Avatar
Trader Rating: 52 (100%+)
damn you james you beat me to it lol. btw chance gave me your transponder
thanks for bringing it back to the east side for me. I'll get it when I see you
Jaz240 is offline
Old 09-14-2011, 07:23 AM
  #3665
The Juice's Avatar
Any thought given to moving the start time for Saturday up since the high will be a chilly 99 degrees?
The Juice is offline
Old 09-14-2011, 09:32 AM
  #3666
Has anyone found a good point for the mechanical timing on their 13.5 motor? This assuming that there is no timing advance or boost in the ESC.
I am currently trying out the the LRP V2 13.5, and the manual indicates that you should not go beyond the factory setting for timing on the motor. But KBRL rules do not allow for timing in the ESC.
Using the +10 degree insert for max timing the motor seems to be running hot.
Matt
msciarrotta is offline
Old 09-14-2011, 09:46 AM
  #3667
Matt
Those LRP motors seem to run hot as it is. I would think any timing would make it worse
mellen_mpz is offline
Old 09-14-2011, 10:06 AM
  #3668
Thanks Mellen.
That's my thinking. It seems like they have about 30 degrees of timing built in to them from what I am reading. I'm going to kick it back down to +5 and see what happens. I wish you could simply turn the endbell. The inserts don't give you the ability to fine tune the timing.
Old 09-14-2011, 10:07 AM
  #3669
KMR
KMR's Avatar
Matt
Matt
Most of the Associated/LRP drivers have been running the 4 Dot timing inserts on the LRP X12 motors. This produces the most power with reasonable heat. “Reasonable heat for X12 is about 185-190deg.” They can handle 200+deg but running it consistently this hot will demagnetize the rotor quickly. Generally running it over 250deg will unsolder the windings in the stator. I recommend running the 13mm rotor if you want to increase the timing to the 3 or 2 Dot timing inserts. The larger rotor will keep the motor much cooler. I apologize I don’t know what each Dot is in timing. There is a noticeable power difference running 2 Dot inserts from stock 4 Dot inserts on the motor. Just watch the heat!
Keoni
KMR is offline
Old 09-14-2011, 10:11 AM
  #3670
Originally Posted by KMR View Post
Matt
Most of the Associated/LRP drivers have been running the 4 Dot timing inserts on the LRP X12 motors. This produces the most power with reasonable heat. “Reasonable heat for X12 is about 185-190deg.” They can handle 200+deg but running it consistently this hot will demagnetize the rotor quickly. Generally running it over 250deg will unsolder the windings in the stator. I recommend running the 3mm rotor if you want to increase the timing to the 3 or 2 Dot timing inserts. The larger rotor will keep the motor much cooler. I apologize I don’t know what each Dot is in timing. There is a noticeable power difference running 2 Dot inserts from stock 4 Dot inserts on the motor. Just watch the heat!
Keoni
Thanks Keoni. That's really good information.
Old 09-14-2011, 01:46 PM
  #3671
Default Start times for Fall
It will be getting cooler soon so we should start thinking about revised start times. I'll bring up the subject at the drivers meeting Saturday and see what the consensus is.
I just talked to Dale and the tracks are ok for practice tonight..
Thanks for the info Keoni!
Dbackmasta is offline
Old 09-14-2011, 02:59 PM
  #3672
Originally Posted by aznitronut View Post
It would be nice cool if one of the Hobbie shops could give us a break, if we had 10 people that would buy one.
I'll give an unbelievable price if you come up with 10. Pm for price.
AZHobbies is offline
Old 09-14-2011, 03:20 PM
  #3673
Jaz240's Avatar
what are Friday practice hours and is it open practice on both tracks?
Jaz240 is offline
Old 09-14-2011, 04:44 PM
  #3674
6p-10p both tracks.
Old 09-14-2011, 05:23 PM
  #3675
Jaz240's Avatar
Jaz240 is offline
You have already rated this thread Rating: Thread Rating: 13 votes, 3.00 average.
