Go Back  R/C Tech Forums > General Forums > 3D Printing Forum
Carbon composite filaments >
Like Tree4Likes
  • 4 Post By daleburr
Old 11-16-2023, 03:22 AM
daleburr's Avatar
Default Carbon composite filaments
I've had stuff printed at work on the SLS machines before using CF Nylon. The parts are mega strong, but there's a fair bit of warping and the tolerances aren't great for small parts.
So I've recently purchased a Bambu X1C, so I can experiment a bit more without hassling the techs at work every day.
The parts above are printed using Prussa PC CF (polycarbonate carbon blend). Its a dream to print. No drying needed, no stringing, layers barely visible.
The printed parts are accurate, stiff and strong. I've tapped the ballstud holes. I tested an early version by trying to rip a stud out with pliers. It was possible but took some effort! The test part failed by the layers detaching, which is a weakness of PC.
I have some PA CF as well which should be even stronger (better layer adhesion), but is a bit harder to print as it has to be thoroughly dried. I'll do a test part and compare to see if its worth the effort.
These particular parts are for wet weather Frontie racing to increase the front camber link length, giving more steering.
daleburr is offline
Old 11-18-2023, 10:41 PM
Prusa PC CF is one of my faves but its definitely spendy at like $60 a spool so I've resorted to cheaper PETG filament. PETG is very strong if you print things with 100% infill.
thegame7 is offline
Old 01-05-2024, 09:18 AM
What would be the best reasonably priced printer that could print using CF?
Lukyduckie is offline
Old 01-06-2024, 01:13 AM
silvertriple's Avatar
Nice. PC is known to have a much better layer adhesion than any other material, I doubt you would get better parts with PA-CF than PC-CF. And from what I heard (and I'm yet to try), PC Blend is probably the best and easier to go (specially for the people not using hardened gears and hardened nozzles)
silvertriple is offline
