What filament?
Old 08-11-2023, 10:56 AM
Default What filament?
What filament would I use to print a Front bumper? Also, what infill would I use?
Thanks!
Gezer2u2 is offline
Old 08-11-2023, 11:55 AM
Super Moderator
Thanks!
Whats it going on?
roadrashracing2 is offline
Old 08-14-2023, 08:54 AM
A touring Car. Thanks for the reply!
Gezer2u2 is offline
Old 08-23-2023, 09:21 PM
Material like ABS or PETG would be good choices. PLA may be too brittle for this application.
You could try a grid or gyroid infill pattern to provide good strength in all directions.
bryants is offline
Old 08-24-2023, 05:05 PM
GerryH's Avatar
Trader Rating: 26 (100%+)
None of those makes a good bumper as they will all fracture with a good hit. Best is to use TEP because it's flexible. Have been using it on my 1/12 scale cars. Problem I ran into is even with a large honeycomb pattern it was significantly more heavy than all the foam bumpers.
I have used PETG to add a top plate to a foam bumper on my TC since it lacked one from the factory. A really hard hit can crack it, but I keep an extra in my spares box.
Are you trying to print a whole bumper for a TC?
GerryH is offline
Old 08-24-2023, 08:56 PM
trilerian's Avatar
Trader Rating: 51 (100%+)
I thought TPU was usedů
trilerian is offline
Old 09-10-2023, 10:11 AM
Yes a whole bumper. Sounds like TPU in 90 Shore is what's needed.
Gezer2u2 is offline
Old 12-29-2023, 12:20 AM
Filament Type: ABS for durability and impact resistance, or PLA for ease of use.
Infill: High infill (70-100%) for added strength. Consider grid or triangular patterns for a balance between strength, material usage, and print time.
For 3D printing a front bumper, use ABS for strength and impact resistance or PLA for easier printing. ABS requires a heated bed and proper ventilation, while PLA is environmentally friendly. For infill, choose high percentages (70-100%) for added strength, and consider grid or triangular patterns. Always check your 3D printer's requirements and filament guidelines, and factor in the intended use and specific characteristics needed for the front bumper.
AeroAstronomer is offline
Old 12-29-2023, 01:08 PM
Why do people feel the need to use AI generated text to answer questions? It's obvious you have no idea what you posted - This info is seriously wrong - nobody would use these filaments for a bumper.
belewis01 is offline
