Go Back  R/C Tech Forums > General Forums > 3D Printing Forum
1/8 caster block and spindles >
Old 11-11-2022, 07:45 AM
Default 1/8 caster block and spindles
I am designing some caster blocks and spindles for a 1/8th nitro buggy. Curious on suggestions for material to use for these parts. Petg, Pla?? If they are successful I will have them machined from aluminum, but wanted to print them first for testing purposes.
silence360 is offline
Old 11-12-2022, 05:00 PM
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
If you are just fit checking etc just some standard old PLA will work fine.. For something printed to hold up to 1/8 scale duty I would start with something like Polycarbonate , or just cut straight to the chase and go for some CF/Nylon.
2wdMod is offline
Old 11-12-2022, 06:22 PM
Great. Thanks for the suggestion!
Old 11-16-2022, 11:31 AM
GerryH's Avatar
Trader Rating: 26 (100%+)
Pretty much any 3d printed part will be weaker along the Z axis. This sometimes can make orienting a part difficult if not impossible based on the stresses it will receive. I once tried unsuccessfully to print a chassis mount for an old Losi XXX-T. It was fine if you went over a small jump square, but as soon as you landed crooked it would break.
What does success mean to you for a 3d printed part?
GerryH is offline
