Go Back  R/C Tech Forums > General Forums > 3D Printing Forum
Making Tires with 3D Printed Molds >
Like Tree147Likes
Old 02-09-2022, 03:35 PM
RC10Nick's Avatar
Default Making Tires with 3D Printed Molds
Hey everyone, I wanted to make a post dedicated to making tires. It turns out slot car guys have been making tires using urethane and silicone casting rubbers for quite some time, but I could only find a small handful of examples of people doing the same for RC car tires, and the ones I did find were for mini-z's. I decided to give it a shot to see if it was possible to make them for (relatively) bigger cars. My first attempts were pretty primative but I've quickly advanced to the point that I can make my own tires to race on.
To start with, here's what can be done at home using relatively inexpensive equipment and materials. This tire cost me roughly $0.30 in resin to make:
Here are some examples of my tires in action. They absolutely work and hold up to real world use. This first video is my Mini-B on a carpet oval track meant for 1RC cars. I'm running a slick I made using a 40A urethane rubber compound. As you can see the tires were quite grippy here.
+ YouTube Video
Next is a video of my Mini-B running on my basement track. It's a smooth, bare concrete surface. The stock Mini-B BK bars were a handful to drive on this surface but as you can see my own square pin tires made using the 40A compound provided a pretty good level of grip. I'd compare it to running on a medium bite outdoor clay track.
+ YouTube Video
I have published all of my files here on Thingiverse for anyone who wants to try this for themselves. You will find my my mold designs as well as the other tooling I use in the process - all 3D printable.
RC10Nick is offline
Old 02-10-2022, 04:54 AM
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
Awesome to see how much further you have taken this since your last post about it in the "what did you print today" thread.
RC10Nick likes this.
2wdMod is offline
Old 02-10-2022, 07:23 AM
RC10Nick's Avatar
Thanks! Your tires and molds were an important bit of motivation and design guidance that pushed me to tackle this project. For anyone else curious, go check out 2wdMod's post history - he makes his own Mini-Z tires and has posted pictures of his molds. He also makes some other really cool 3D printed projects worth checking out, too.
But now I want to go over my process for making tires. To start with, here are the chemicals I've been using so far:
On the left if the VytaFlex 60. It's a very firm/stiff urethane rubber that I've found is good for carpet tires. It has a long pot life and a long demold time. The long pot life gives me plenty of leeway when mixing, degassing, and injecting. However, the long demold/cure time means I feel like I'm waiting forever before I can actually demold the tires. It's a tradeoff for sure, but I've had less problems and less scrapped tires since I started using this stuff. The only real downside is I've found it to be a much sticker resin - as in if there's not enough mold release applied to the mold, I'm lucky if I can get the tire out in one piece. You can get this stuff on Amazon.
In the middle is the Stoner Urethan Mold Release. Also available on Amazon. This stuff is essential, and I have found I can get several pulls out of a single application. I've been using the same can since I started six months ago so unless you're running a commercial operation this stuff should last you a decent while.
On the right is the Simple Resin EnduroSOFT urethane rubber. You used to be able to get this stuff on Amazon but now they have their own website. It's also the cheapest resin I've found. It's a soft 40A rubber with a much shorter pot life and demold time. I use this compound for the tires I run on my bare concrete basement floor. I find them to be plenty grippy on that surface with a decent tread life. I tried running these at the local carpet track and they burned up in less than one pack. The shorter pot life means this stuff is trickier to work with. Any mistake or delay in getting this into the mold after mixing it and you're pretty much done. I never have enough time to fully degas this stuff so I tend to have more failed tires using this stuff.
To get the most out of your resins you'll need a vacuum pump and chamber as well a pressure pot. After mixing the resin you'll want to stick it in the vacuum chamber to degas it and get out all the air bubbles. Once you get the resin into the mold you'll want to stick the mold in the pressure pot so any air bubbles that may have formed or become trapped in your mold get compressed. More on this equipment below.
Here is my mold design:
It has four pieces that get bolted together by four M5 screws/bolts. Once bolted together I use a 3D printed syringe to inject the resin into the top of the mold, where it follows the path shown by the red arrows in the picture below. It's critical for the resin to fill the mold cavity from the bottom as that forces out the air without trapping any air in the mold.
One of the key innovations I developed in the design of my mold that I'm quite keen to point out and share is the use of inset nuts and washers to aid in demolding. One of the initial challenges I faced is how the heck do you get your mold apart after the resin cures?
I've added inset nuts to the outer mold halves and inset metal washers to the middle mold piece. This allows me to drive a screw into the mold as shown below. As the screw is driven in it pushes against the washer on the middle mold piece and easily forces the two pieces apart. Flip over and repeat for the other half and you've got your tire demolded without damage to yourself, your part, or your mold!
Another quality of life improvement I added into my mold was a channel on the top of the mold to contain the excess resin that escapes out the top of the mold. It's not critical and not all of my molds have it, but it does help keep things just that little bit cleaner and tidier.
One of the biggest struggles I faced, and arguably a bigger struggle than designing the molds and casting the tires, was producing a foam insert. Early on I tried something like a press to punch out the inserts and it worked on some packaging foam I had tried it on, but it did not work for the soft open cell foam we use for tires. I eventually came up with this medieval looking contraption:
It's simple to use and very effective. Stab a piece of foam through the bolt like so:
And press the x-acto blade holder directly down into the foam. Lift the blades up, rotate them a little bit, press back down into the foam, and repeat until you've cut yourself a beautifully perfect looking tire insert.
To ensure a high level of success when making tires you will need some more expensive equipment - a vacuum pump, vacuum chamber, air compressor, and pressure pot. For making slicks you can sometimes get away without this extra equipment, but treaded tires will be difficult, if not impossible, without them.
Unfortunately I don't think you can cheap out on the vacuum setup - I tried. You'll have to get a pump and a chamber and that will set you back about $150 for a cheap one on Amazon. However, before I had a vacuum chamber I got by simply by being very gentle while mixing up the urethane resin and when I decanted the resin into my syringe I held the cup with the resin at about head height and the syringe at about waist height. I poured slowly so the stream of flowing resin was as thin as possible. Pouring the resin like that can help get rid of any big air bubbles. It's not a guarantee for success, but it works well enough to play around without making tires before committing to buy a vacuum pump.
You can go cheap on the pressure pot. I have one of those small airbrush compressors I use to paint up my bodies. That compressor easily puts out enough pressure for what I need. The CFM is low, but we don't need very much CFM at all here. When you've got resins that take hours to set, a few extra minutes to pressurize a chamber doesn't matter. As for the chamber, you can find examples of inexpensive DIY versions on youtube and try building one yourself. That's basically what I did and for about $30 in materials I have a chamber just big enough for two of my molds.
RC10Nick is offline
Old 02-11-2022, 04:45 AM
RC10Nick's Avatar
I updated my other two posts to make things a bit more clear and I've also added a link to all of my files on Thingiverse for anyone who wants to try making their own tires.
2wdMod and two shoes like this.
RC10Nick is offline
Old 02-18-2022, 09:56 AM
RC10Nick's Avatar
Happy friday everyone! I've got a big update today.
To start with, I uploaded a new mold design to Thingiverse today: https://www.thingiverse.com/thing:5252607
This is a simple mold I designed early on in my tire making journey that I was able to use to make tires without the need for a pressure pot or vacuum degassing chamber. I wanted to give people a project they could try out without having to throw loads of money at expensive equipment.
To go along with this mold design, I've created and uploaded a short video series on Youtube.
My goal with the video series was to share everything I've learned about resins and molds and how to make tires. The first video covers the resins, the second video covers what I've learned about designing molds, and the third video is a step by step instruction walkthrough on how to make tires using the simplified mold design.
+ YouTube Video
+ YouTube Video
+ YouTube Video
RC10Nick is offline
Old 02-18-2022, 02:22 PM
two shoes's Avatar
Trader Rating: 21 (100%+)
WOW!
two shoes is offline
Old 02-18-2022, 05:33 PM
Nice !! I am about to do a video walk through for the mold files I am including with my 1/24 pan car kit.. That would be another cheap project as it doesnt require apressure pot or degassing.. BTW I am in the process of debunking the dont use silicone on RCP thing.. I think the silicone that was causing issues was the peroxide/TIN cured compounds not the current platinum cure that was actually developed for the food safe world... I have been running Platinum cure 20 shore rears and 30 shore fronts on my track for a few weeks now with no signs of damage.. Just ordered some 15A so I will be trying 15a rears and 20 a fronts to see if I can lock the cars in a bit more with the homebrew tires.. Right now the 20R/30F combo works for practice on 2s, they would probably be dialed for 1s/4AAA "stock".. The 20a front slicks I have made pair great with some 20 shore Kyosho Radials in the rear until the tread ghosts out to slicks... I am hoping the 15a Rear slicks are nice and balanced with the 20a fronts or else I am going to be designing some radial tread rear molds ..LOL
RC10Nick and two shoes like this.
2wdMod is offline
Old 02-19-2022, 06:06 AM
RC10Nick's Avatar
Cool! I hope it works out for you! Even in the slot car world where silicone and urethane tires are more common I found there's still strong resistance to their use. Apparently silicone ruins the track for anything other than silicone tires and the rubber purists who know all the tire voodoo don't like that urethane tires have consistent high levels of grip without needing to be treated in any way (kinda like the debate between brushed and brushless back in the early 2000's).
2wdMod likes this.
RC10Nick is offline
Old 02-19-2022, 06:43 AM
Oh I know, its a great rabbit hole of mythology and partial truths. Some of us older guys remember when people were making tires out of permatex and silicone caulk .. both of which leave residues and leach out chemicals after cure.. The food safe compounds do not , which is why they are food safe, they dont leach after cure where TIN cure does.. So I could definitely see where the peroxide/TIN cure compounds could leave a residue on the track..
2wdMod is offline
Old 02-22-2022, 05:27 AM
RC10Nick's Avatar
Okay, now that I've got everything figured out it's time to start making bigger tires. Here's my first attempt at something a little bigger. It's a square pin tire designed to fit a 26mm 1/10 touring car wheel. I made it using the 60A urethane because I want to use these as carpet tires for my LC12B1. It turned out just as good as the mini tires I've been making so I'm starting to feel pretty confident I'll be able to make 1/10 off-road tires which is my ultimate goal. I want to have a full set of 4 of these made by Friday so I can race them at my local carpet track.
RC10Nick is offline
Old 02-22-2022, 09:48 AM
Very Nice!!
2wdMod is offline
Old 02-24-2022, 05:55 PM
RC10Nick's Avatar
Thanks!
Here it is with the insert I made for it. I designed and printed out a slightly larger version of my medieval torture device insert cutter.
And here's the full set mounted up on my LC12B1, ready to race tomorrow night on carpet:
RC10Nick is offline
Old 02-28-2022, 06:10 AM
RC10Nick's Avatar
No pictures today, but I did try putting one of my tires into acetone to see what would happen if I wanted to remove them from a wheel. The tire was submerged halfway into the acetone. The half that was submerged ballooned up massively in about 4 hours. The half that wasn't submerged ballooned up a little bit, too, but nowhere near as much. I took the tire out after I checked on it and let it sit on my bench for a few days. It has now shrunk back to its original size and the rubber seems unaffected by it other than some discoloration on the portion that was submerged. It's a pretty interesting result. The next test will be to try to remove a tire from a wheel and re-use it.
Anyway, the reason I did all of this is because I took the tires to the track on Friday and while they had a lot of grip and the tread barely showed any wear, I think I want to use a wheel with a wider offset. The car felt pretty unstable with all the extra grip and I think some extra width might help tame that down. I don't want to have to cast a brand new set of four tires so if I can just acetone the tires off of the wheels and re-use them that would be idea..
RC10Nick is offline
Old 03-03-2022, 04:44 AM
The weather was nice enough I got to test my cast tires on sealed asphalt yesterday.. 15 A rears with 30a fronts for long flowing stuff , 15a rears with 20a for tight technical stuff.. Yeah we just had our entire neighborhood repaved last year, so my neighbors are going to be wondering what all the paint dots are in the road.. (corner markers)
two shoes likes this.
2wdMod is offline
Old 03-09-2022, 01:23 PM
Little off subject , But I still printed Molds to cast some silicone parts.. I made some font suspension springs for my 1/24 cars.. In testing a PN medium , green spring exerts 168 grams of force under 1.5mm of compression.. My cast silicone springs made form 15a silicone, tests out at 173grams of force exerted under 1.5mm of compression.. In driving it acts near identical to the green PN, so yeah, now to cast some in 20a and see where they scale out at ..
two shoes and Bry195 like this.
2wdMod is offline
You have already rated this thread Rating: Thread Rating: 2 votes, 4.50 average.
