Go Back  R/C Tech Forums > General Forums > 3D Printing Forum
Higher print temps for Ender 3 Pro?? >
Old 05-01-2020, 11:41 AM
petersen114's Avatar
Default Higher print temps for Ender 3 Pro??
Wanting to pull the trigger on this printer and I am aware that I have to add the Micro Swiss all metal hot end. I am curious as to what is the best way to change the firmware to raise the temperature above the preset 250 max needed to print nylon.
petersen114 is offline
Old 05-04-2020, 07:24 AM
Trader Rating: 27 (100%+)
Flash with marlin. FYI I print PTEG at about 240 on the stock hotend regularly. Not quite as tough as nylon but so much easier to print.
sacmiata is offline
Old 05-18-2020, 06:10 PM
Riketsu's Avatar
Trader Rating: 33 (100%+)
In order to flash the stock motherboard you need a bootloader, costs around $7-$8 in eBay.
Many users have switched to SKR Mini E3 V1.2 (2.0 was released today) for $35 (Amazon or $28 on Aliexpress if you are willing to wait). This board quiets down the printer A LOT and you can flash it with custom firmware (changing presets, enabling safety features, etc.)
Riketsu is offline
Old 05-19-2020, 08:40 PM
I love my Ender 3 Pro and I installed the bootloader to my stock board in order to play around with Marlin 2.0 but ended up going down to 1.9. If I had to do it over again, I would upgrade to a better board, especially since they aren't too expensive. I'm still rocking the stock board so it's not that the board is bad but you'll see what I mean once you start your "bootloader" journey.
Werty Yui is offline
Old 05-20-2020, 10:02 AM
Riketsu's Avatar
The $30 is well worth it for removing the annoying chirping sound of the motor drivers.
I'm currently running Marlin 2.0.5.3 with no issues.
Riketsu is offline
Old 05-21-2020, 09:06 AM
I plan on upgrading my board at some point, in particular, to a 32bit board down the line. When I decided to update my firmware, it was primarily to get the disabled thermal protection enabled. 32bit boards weren't even officially released at the time for the Ender 3 Pro so I decided to flash the stock and wait the new boards out. It was quite a journey dealing with issues getting the bootloader to flash and the limitations of an 8bit board means anyone using one in an Ender 3/Pro will be best served using Marlin 1.9 since it's better optimized for 8bit board versus 2.0+ which is the opposite. Bottom line, new board is the way to go but not 100% necessary.
