Gears
Old 10-10-2019, 08:46 AM
Default Gears
This is what i got so far
Has anyone tried pla+ for gearing on a RC car? I know nylon is number one choice it seems but my MP select v2 won't print it.
speedworks is offline
Old 10-11-2019, 01:48 AM
J SiN's Avatar
I got 3 feet with the pla+ one I tried
J SiN is offline
Old 10-11-2019, 03:54 AM
I've printed nylon with my MP select mini V1 running a $9 v6 knock off hot end. Nylon is, however, a little more floppy than I'd like for RC parts.
anthonyscardina is offline
Old 10-11-2019, 04:37 AM
Did you do anything to motherboard or add any sensors to get hotend to work correctly?
Old 10-11-2019, 04:38 AM
Man that's not good, how did it break? Electric or nitro vehicle?
Old 10-11-2019, 06:34 AM
TheRulesLawyer's Avatar
I can't imagine PLA gears taking any amount of power without being super wide for RC. Maybe the idler gears in my mini... they are like 1cm wide so huge relatively. I should try some on my resin machine though. The siatech blu is supposed to be fairly strong and I could actually get a clean enough print for the them to mesh well.
TheRulesLawyer is offline
Old 10-13-2019, 01:41 PM
I used the existing heater and thermistor from the stock hot end, and did not make any changes to anything else.
Old 10-13-2019, 03:25 PM
Ok, just went to my mini v2 and firmware will only let hotend hit 280c max. Thought nylon needed 300 or more? Also how hot did you set the bed temp? And did you enclose the printer to hold heat in?
Old 10-13-2019, 03:26 PM
I would love to see one of those resin gears made.
Old 10-13-2019, 03:28 PM
Have a little update, tried that pla+ gear and it worked. So far only have one tank of ripping 360's and holeshots but its holding up. Gear is around 6mm thick with 25% infill.
Old Yesterday, 08:01 AM
Send me a STL and I'll print you one. PM me if you want to hook up.
Old Yesterday, 10:00 AM
I did some 4:1 helical bevel gears for an FPV Rover 2.0 build ( thing# 2952852 on thingiverse - can't do link in first post) as a re-mix of the original straight bevel 2:1 gear set, printed from both PLA & PLA+. They are holding up pretty well so far even with a bit of abuse. That said, I consider the parts consumable & keep extras on hand for the time when they eventually break or wear. The rover is powered by two brushed 540 motors & a 2S lipo battery.
I'd post pics & video links, but that is not permitted on a first post.
nikdfish is offline
Old Yesterday, 10:08 AM
I did the initial design using an involute gear library in OpenSCAD, then fleshed out the connection profiles in Tinkercad. It did take a couple of trial & error prints to get the gear mesh right due to the differences in gear height between original design & remix. The motor mount was a fixed quantity due to size & placement, so I needed to mod the gears to get a correct gear interface.
nikdfish is offline
Old Yesterday, 10:18 AM
Sent ya a PM
Old Yesterday, 10:21 AM
Good to hear your having good luck with pla+ gears also. Ill keep this post updated with how mine hold up over time.
